[OpenLayers-Users] Cannot display search marker when projecting layers to EPSG 900913
Andrew Parker andrew at source3.com
Mon Dec 1 08:23:20 EST 2008
Hello Group,
I have been working with the MapFish user groups helping me build
http://webmap.rthicksconsult.com.  I followed many discussions on EPSG
900913 and EPSG 3785 on the OpenLayers group and believe that the
OpenLayers community may be able to help me.
I am in the process of projecting all layers to EPSG 900913 (spherical
mercator) so that my WMS layers align with google base layers.  So far,
the Geology, Amigo, and Water Wells layers align fine.  I also got the
google geocoder to center the map properly.  But I am having difficulty
getting the search marker and USGS topographic map layers to display.
The projected web map with the PROBLEMS is at
http://webmap.rthicksconsult.com/index_prj.html
The ORIGINAL unprojected web map (the original map that displays topos
and site marker) is at http://webmap.rthicksconsult.com
I am not sure if the issue is in my MapServer map file, the
map.addLayer(), or somewhere else.
The MapServer mapfile which generates the marker for the search is
reproduced below.  I passed the lat/long
variable both in epsg 900913 and 4326, this made no difference.  I also
have an alert box pop up to verify the coordinate transformation when
the submit to location button is activated.
I also included portions of the mapfile that renders my layers for the
projected web map.
The USGS Topo layer is servered directly from TerraServer via WMS.  The
USGS Topo2 layer is servered from MapServer via TerraServer.  Topo and
Topo2 render in the unprojected state.
Thank you for the help.
~andrew parker
PS:  I am using this site for guidance:
http://docs.openlayers.org/spherical_mercator/
radius_prj.map called by ggeocoder_prj.js
NAME "Radius"
STATUS ON
SIZE 800 800
IMAGECOLOR 255 255 255
IMAGETYPE PNG
OUTPUTFORMAT
  NAME "png"
  MIMETYPE "image/png"
  DRIVER "AGG/PNG"
  EXTENSION "png"
  IMAGEMODE RGBA
  TRANSPARENT on
END
OUTPUTFORMAT
  NAME "gif"
  MIMETYPE "image/gif"
  DRIVER "GD/GIF"
  EXTENSION "gif"
  TRANSPARENT on
END
UNITS meters
PROJECTION
  "init=epsg:26910"
END
SYMBOLSET "symbols.sym"
WEB
  IMAGEPATH "/maps/images.tmp/"
  IMAGEURL "/images.tmp/"
  METADATA
    "wms_title" "mapfile"
    "wms_onlineresource"
"http://216.93.173.156/cgi-bin/mapserv?map=radius_prj.map"
    "wms_srs" "EPSG:4269 EPSG:4326 EPSG:900913 EPSG:3785"
  END
END
LAYER
  NAME "groundzero"
  TYPE point
  CONNECTIONTYPE postgis
  CONNECTION "user=**** dbname=***** password=***** host=localhost"
   METADATA
  WMS_SRS  'epsg:4326"
  WMS_TITLE 'groundzero'
  # WMS_FEATURE_INFO_MIME_TYPE 'text/html'
END #METADATA
  # the data is a dynamically constructed point, wherever they specified
  DATA "the_geom from (SELECT 1 as
gid,transform(GeometryFromText('POINT(%centerx% %centery%)',4326),26910)
as the_geom) as foo using unique gid using srid=26910"
  CLASS
    STYLE
      SYMBOL "/maps/data/marker.png"
    END
  END
END
END # end of mapfile
projection.map
NAME "R.T. Hicks Web Map MS.1"
STATUS ON
SIZE 800 640
IMAGETYPE PNG
OUTPUTFORMAT
   NAME "png"
   DRIVER "AGG/PNG"
   EXTENSION "png"
   IMAGEMODE RGBA
   TRANSPARENT on
END
OUTPUTFORMAT
   NAME "gif"
   DRIVER "GD/GIF"
   EXTENSION "gif"
   TRANSPARENT on
END
SHAPEPATH "/maps/data/shapefiles/"
UNITS dd
EXTENT -110.25 30.518768 -102.001961 37.500294
PROJECTION
   "init=epsg:4326"
END
FONTSET "fonts/font.list"
WEB
   MAXSCALE 3500000
   MINSCALE 100
   METADATA
"http://216.93.173.156/cgi-bin/mapserv?map=/maps/data/mapfiles/projection.map"
   END
END
SCALEBAR
   IMAGECOLOR 192 192 192
   COLOR 0 0 0
   LABEL
     COLOR 0 0 0
     SIZE medium
   END
   STYLE 1
   SIZE 288 6
   UNITS MILES
   INTERVALS 4
   STATUS ON
END
REFERENCE
   EXTENT -104.86 31.96 -100.02 33.6
   SIZE 120 120
   STATUS on
   COLOR -1 -1 -1
   OUTLINECOLOR 255 0 0
END
LEGEND
   KEYSIZE 18 12
   LABEL
     TYPE BITMAP
     SIZE MEDIUM
     COLOR 0 0 0
   END
   STATUS ON
END
LAYER
  NAME 'Geologic_Map'
  #TEMPLATE 'Geologic Map_query.html'
  STATUS off
  TYPE Polygon
  OPACITY 70
  # TOLERANCE 7
  # TOLERANCEUNITS pixels
  CONNECTION "user=***** dbname=***** password=***** host=localhost"
  DATA "the_geom from geology"
  GROUP "Base Map"
  METADATA
   WMS_SRS  'epsg:4326'
   WMS_TITLE 'Geology'
  END #METADATA
  PROJECTION
   'init=epsg:4326'
  END
  CLASSITEM 'map_unit'
  LABELITEM 'map_unit'
  LABELMAXSCALE 300000
  CLASS
   NAME ' , <Null>'
   EXPRESSION ('[map_unit]' eq '<Null>')
   STYLE
    COLOR 199 157 149
    OUTLINECOLOR 110 110 110
   END #STYLE
#...BREAK IN LAYER
END #LAYER
#...OMITTED EXTRA LAYERS
LAYER
   NAME "USGS_Topo"
   STATUS OFF
   TYPE RASTER
   MAXSCALE 19000001
   MINSCALE 5099
   GROUP "Base Map"
   CONNECTIONTYPE WMS
   CONNECTION "http://terraservice.net/OgcMap.ashx?"
   METADATA
     "wms_srs"    "EPSG:4326"
     "wms_title"    "TopoMaps"
     "wms_name"    "DRG"
     "wms_server_version"    "1.1.1"
     "wms_format"    "image/jpeg"
     "wms_layers"    "drg"
     "wms_group_title" "background"
   END
   PROJECTION
     "init=epsg:4326"
   END
END
LAYER
   NAME "USGS_GroundwaterElevation"
   STATUS off
   TYPE point
   CONNECTION "user=****** dbname=***** password=***** host=localhost"
   DATA "the_geom from nmusgs"
   #MINSCALE 500
   #LABELMAXSCALE 1076189
   # MAXSCALE 2000000
   GROUP "USGS Data"
   #TEMPLATE "/maps/query_ROC.html"
   # TOLERANCE 7
   PROJECTION
     "init=epsg:4326"
   END
   OPACITY 100
   LABELITEM "gwelev"
   METADATA
     "wms_title" "nmUSGS"
   END
   CLASS
     NAME "nmusgs"
     STYLE
       COLOR 255 0 0
       SYMBOL "point_triangle"
       SIZE 10
     END
     LABEL
       TYPE truetype   # use truetype font
       FONT "Arial"  # use arial bold
       SIZE 8          # use 8 point size
       COLOR 255 0 0   # color text coral
       BACKGROUNDCOLOR 255 255 255 # render text on white bg
       MINDISTANCE 50  # labels > 50 pixels apart
       POSITION auto     # center labels below feature
       ANTIALIAS true  # antialias the text
       PARTIALS false
     END
   END
END
LAYER
   NAME "OSE"
   STATUS off
   TYPE point
   DATA "the_geom from ose"
   #MINSCALE 500
   # MAXSCALE 2000000
   GROUP "Environmental"
   # TOLERANCE 7
   PROJECTION
     "init=epsg:4326"
   END
   OPACITY 100
   LABELITEM "depth_wate"
   METADATA
     "wms_title" "OSE"
   END
   CLASS
     NAME "OSE"
     STYLE
       COLOR 0 191 255
       SYMBOL "point_circle"
       SIZE 10
     END
     LABEL
       SIZE 11          # use 8 point size
       COLOR 0 191 255   # color text coral
       #BACKGROUNDCOLOR 255 255 255 render text on white bg
       #MINDISTANCE 50   labels > 50 pixels apart
       PARTIALS false
     END
   END
END
LAYER
   GROUP "AMIGO"
   NAME "SaturatedThickness"
   STATUS off
   TYPE RASTER
   DATA "SatThkYr2040.tif"
END
LAYER
   GROUP "AMIGO"
   NAME "Conductivity"
   STATUS off
   TYPE RASTER
   DATA "MushchudK1.tif"
   METADATA
     "wms_title" "Conductivity"
   END
END
