[OpenLayers-Users] DrawFeature with callback?
Adorian Ardelean
mynature at gmail.com
Fri Dec 5 08:35:45 EST 2008
Hi Nino,
This works ok for me:
dosomething = function (feature)
//do something with polygon
alert("yeeehaaa");
controls = {
polygon: new
OpenLayers.Control.DrawFeature(regions,OpenLayers.Handler.Polygon,
{'featureAdded': dosomething})
All the best,
Adorian
On Fri, Dec 5, 2008 at 2:03 PM, Nino Saturnino Martinez Vazquez Wael <
nino.martinez at jayway.dk> wrote:
> Okay so I now have this, still not working though:
> <html xmlns="http://www.w3.org/1999/xhtml">
> <head>
> <title>OpenLayers Regular Polygon Example</title>
> <script src="http://openlayers.org/api/OpenLayers.js"></script>
> <script type="text/javascript">
> var map, polygonControl;
> OpenLayers.Util.onImageLoadErrorColor = "transparent";
> function init(){
> map = new OpenLayers.Map('map');
> var wmsLayer = new OpenLayers.Layer.WMS( "OpenLayers
> WMS",
> "http://labs.metacarta.com/wms/vmap0?", {layers: 'basic'});
> var polygonLayer = new OpenLayers.Layer.Vector("Polygon Layer");
> map.addLayers([wmsLayer, polygonLayer]);
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> map.addControl(new OpenLayers.Control.MousePosition());
> dosomething = function (polygon)
> alert("yeeehaaa");
> polyOptions = {sides: 4, callbacks: {'featureAdded': dosomething}
> polygonControl = new OpenLayers.Control.DrawFeature(polygonLayer,
> OpenLayers.Handler.RegularPolygon,
> {handlerOptions: polyOptions
> map.addControl(polygonControl);
> map.setCenter(new OpenLayers.LonLat(0, 0), 3);
> document.getElementById('noneToggle').checked = true;
> function setOptions(options) {
> polygonControl.handler.setOptions(options);
> function setSize(fraction) {
> var radius = fraction * map.getExtent().getHeight();
> polygonControl.handler.setOptions({radius: radius,
> angle: 0});
> </script>
> </head>
> <body onload="init()">
> <h2 id="title">OpenLayers Regular Polygon Example</h2>
> <p id="shortdesc">
> Shows how to use the RegularPolygon handler to draw features with
> different numbers of sides.
> </p>
> <div id="map" class="smallmap"></div>
> <div id="config">
> <ul id="controls"><b>Map Controls</b>
> <li>
> <input type="radio" name="type"
> value="none" id="noneToggle"
> onclick="polygonControl.deactivate()"
> checked="checked" />
> <label for="noneToggle">navigate</label>
> </li>
> <li>
> value="polygon" id="polygonToggle"
> onclick="polygonControl.activate()" />
> <label for="polygonToggle">draw polygon</label>
> </li>
> </ul>
> </div>
> </body>
> </html>
> Adorian Ardelean wrote:
>> Hi,
>> I presume you have to specify the event name somehow. Try including this:
>> ...callbacks: {'featureAdded': dosomething}...
>> All the best,
>> Adorian
>> On Fri, Dec 5, 2008 at 12:59 PM, Nino Saturnino Martinez Vazquez Wael <
>> nino.martinez at jayway.dk <mailto:nino.martinez at jayway.dk>> wrote:
>> Hi Guys
>> Im doing a integration for the Apache Wicket framework(
>> http://wicketstuff.org/confluence/display/STUFFWIKI/wicket-contrib-openlayers
>> ), and want to add some more features. Im looking into adding the
>> possibility to draw polygons, however I cant find a example where
>> theres
>> a simple callback involved once the polygon are drawn, however the api
>> mentions it's possible.
>> As you can see from the below code the only thing I need for this
>> little
>> thing to work are the function that calls the alert to be picked up.
>> Please say if you want me to elaborate further.
>> <head>
>> function init(){
>> var wmsLayer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>> 'basic'});
>> Layer");
>> {function(value){alert('yeeeha');}} };
>> {handlerOptions:
>> polyOptions
>> document.getElementById('irregularToggle').checked =
>> false;
>> angle: 0});
>> </script>
>> </head>
>> <p id="shortdesc">
>> </p>
>> <div id="config">
>> <li>
>> </li>
>> <li>
>> </li>
>> </ul>
>> </div>
>> </body>
>> </html>
>> -Nino
>> Users mailing list
>> Users at openlayers.org <mailto:Users at openlayers.org>
>> http://openlayers.org/mailman/listinfo/users
>> Dr. Adorian Ardelean
>> coordinator of myNature Project
>> http://mybiosis.info/nature/portal.php?pagename=firstpage [a Romanian
>> biodiversity-database]
>> http://mybiosis.info/nature/portal.php?pagename=adorian [CV]
> -Wicket for love
> Nino Martinez Wael
> Java Specialist @ Jayway DK
> http://www.jayway.dk
> +45 2936 7684
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081205/4b7ab2d5/attachment.html
