[OpenLayers-Users] Support for GeoRSS polygons in different spatial
refs
Michael Östling
michael.ostling at metagis.se
Fri Dec 5 11:05:55 EST 2008
Can anyone give me some light on how OpenLayers can handle GeoRSS.
I would like to show Polygons in EPSG:2400 without any transformation.
The map is also n EPSG:2400.
Reading the documentationI I guess it is only Points that could be used by
the GeoRSS-layer in OL and no referencesystems could be defined.
Is this "GeoRSS Simple" that the Layer-type GeoRSS can read and render?
Is there no support for GeoRSS-gml?
When looking into the sample
http://www.openlayers.org/dev/examples/vector-formats.html
I can see that the GeoRSS layer is used to read GeoRSS -data but it is
rendered by a vectorlayer.
Is this still geoRSS-simple?
If I want to show polygons with GeoRSS OL should I then use the same method
as in the example above or is there
an other way?
If anyone could describe this then I would be very happy.
mvh
Michael
MetaGIS AB
Michael Östling
Mob: 070-279 19 76
Tel: 023 - 702 20 10
ePost: michael.ostling at metagis.se
SKYPE: MichaelOstling
MSN: metagis at hotmail.com
www: http://www.metagis.se
Adress: Britsarvsvägen 28a, 791 36 FALUN, Sweden
Org Nr: 556638-7170
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081205/d38973cd/attachment.html
