[OpenLayers-Users] WFS popup alignment
Arnd Wippermann
arnd.wippermann at web.de
Fri Dec 5 12:57:35 EST 2008
If you use OpenLayers.Layer.MapServer you can use the parameter
map_projection to change the projection on the fly.
http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg12820.html
Arnd Wippermann
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Joanne Cook
Gesendet: Freitag, 5. Dezember 2008 18:23
An: Andrew Parker
Cc: users at openlayers.org
Betreff: Re: [OpenLayers-Users] WFS popup alignment
Hi Andrew,
I did eventually figure out that it was the "spherical mercator" problem,
again, though I was/am confused as to why the popup would be placed
correctly yet the feature it was derived from was not!
Unfortuntely, it's not always possible to get enough access to alter the
epsg file and add 900913 support for mapserver. For example, you may have
access to only the web folders on a server (from personal experience). In
those cases, you have to find a different solution to the problem, although
of course you can use different background imagery and eschew the commercial
layers...
Thanks again
Jo
Joanne Cook
Senior IT Support and Development
Oxford Archaeology (North)
01524 880212
http://thehumanjourney.net
----- Original Message -----
To: users at openlayers.org
Sent: Thursday, 4 December, 2008 15:32:08 GMT +00:00 GMT Britain, Ireland,
Portugal
Subject: Re: [OpenLayers-Users] WFS popup alignment
Hello Joanne:
I am headed out of the office but wanted to give you something to
consider....have you read: http://docs.openlayers.org/spherical_mercator/
which discusses projection issues using google, yahoo, ve, etc with user
created layers.
Also, I am working on projection issues as well. I started a post which
discusses projection issues which may help you with yours. If you go to my
layer intialization script (
http://webmap.rthicksconsult.com/c2corgCreateMap_projection.js ) you will
see how I had to add {'shericalMercator':true}. As an example
gsatellite = new OpenLayers.Layer.Google("Google Satellite",
{type:G_HYBRID_MAP, 'sphericalMercator': true, buffer:0} );
map.addLayer (gsatellite);
My thread is at
http://www.nabble.com/Cannot-display-search-marker-when-projecting-layers-to
-EPSG-900913-td20771840.html#a20771840 .
Hope this will give some insight to your issue.
Andrew Parker
Joanne Cook wrote:
Hi List,
I have both WMS and WFS layers from a postgres table (starting with WMS but
moving to WFS as you zoom in), on top of Microsoft Virtua Earth. You click
the WFS points and get a framedcloud popup of the feature attribute data.
This aspect works fine, but there is an issue with the alignment of the WFS
points. There are some zoom levels where I can see that the WFS layer does
not align correctly with the WMS, this is worse at the bottom of the map
square and better towards the top. Not only that, the anchor for the popup
aligns correctly with the WMS rather than the WFS. So you click on a point
and the popup appears next to the correct location rather than where you
have clicked.
I assume this is something to do with projections, but I'm a little stuck
and would appreciate some assistance. I can't show the map itself because it
isn't available to the outside world, but the salient bits of the code are
here:
var map, ve, wms, wfs, drawControls, selectControl, selectedFeature;
function onPopupClose(evt) {
selectControl.unselect(selectedFeature);
function onFeatureSelect(feature) {
selectedFeature = feature;
var projcode =
selectedFeature.attributes['projcode'];
var sitecode =
selectedFeature.attributes['sitecode'];
var projnam = selectedFeature.attributes['projnam'];
var year = selectedFeature.attributes['year'];
popup = new OpenLayers.Popup.FramedCloud("info",
feature.geometry.getBounds().getCenterLonLat(),
null,
"<div style='font-size:.8em'>Project
Code: " + projcode +"<br />Site Code: " + sitecode+"<br />Project Name: " +
projnam + "<br />Year: " + year + "</div>",
null, true, onPopupClose);
feature.popup = popup;
map.addPopup(popup);
function onFeatureUnselect(feature) {
map.removePopup(feature.popup);
feature.popup.destroy();
feature.popup = null;
function init(){
map = new OpenLayers.Map('map');
ve = new OpenLayers.Layer.VirtualEarth( "Virtual Earth",{'type':
VEMapStyle.Hybrid});
wms = new OpenLayers.Layer.WMS("OA Sites WMS",
"http://10.0.10.106/cgi-bin/mapservpostgis.cgi?" ,
{layers: 'oasites', transparent: true,
format: 'image/png', buffer:0},
{isBaseLayer: false, reproject: true},
{scales: [14000000,500000]});
wfs = new OpenLayers.Layer.WFS("OA Sites WFS",
{typename: 'oasites', maxfeatures: 200,
featureNS: ' http://mapserver.gis.umn.edu/mapserver ', typename:
'ms:oasites'},
{scales: [500000, 10], extractAttributes:
true},
{style:
OpenLayers.Util.extend({},OpenLayers.Feature.Vector.style['default'])});
Thanks
Jo
Joanne Cook
01524 880212 http://thehumanjourney.net ------
Files attached to this email may be in ISO 26300 format (OASIS Open Document
Format). If you have difficulty opening them, please visit
http://iso26300.info for more information.
Users mailing list Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
Users mailing list
Users mailing list
