[OpenLayers-Users] wfs-t modify problem
Indika Tantrigoda indika85 at gmail.com
Fri Dec 5 23:03:03 EST 2008
Hi Andreas,
I found the solution to the issue by applying
http://trac.openlayers.org/ticket/1787
Improper tynenames was the issue.
Regards,
Indika
2008/12/4 Andreas Hocevar <ahocevar at opengeo.org>
> Hi,
> On Thu, Nov 20, 2008 at 7:06 PM, Indika Tantrigoda <indika85 at gmail.com>
> wrote:
> > Hello to all,
> > In my wfs-t modification request the tag is as follows
> > <wfs:Update typeName ="features">
> > which I am guessing is causing a problem. Should typeName =
> > "features:cities" or  typeName="topp:cities" be present here instead ?
> You should provide the relevant snippets of your javascript code.
> Without knowing what you have done, it is hard to tell you what might
> be wrong.
> Regards,
> Andreas.
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081206/a4c06482/attachment.html
