[OpenLayers-Users] Using OpenLayers for interactive plotting
eider at fh-bingen.de
Sun Dec 7 13:35:20 EST 2008
Hi Bobby,
from mypoint of view, it could be possible to abuse OL as a viewer for
your mathematical plots.
You just have to create a new layer, whose points are calculated based
on a mathematical function.
But here arise my problems:
Coordinates are from my point of view discrete values. Your
math-function is non discret.
So your layer could calculate its values based on the x-coordinates of
your actual window, where each y-value would be connect by a line.
When zooming in each line would first show an interpolation of the
values between the y-values of 2 x-coordinates, but you should do a
recalculating.
But it could work.
You sould think about the location of your calculating process:
client-side within javascript or server-side with ?????
For drawing the background lines and units of your coordinate-system you
can use a image layer
Cheers Carsten
Quoting "Bobby Moretti" <bobmoretti at gmail.com>:
> Hi,
> I'm interested in making an interactive, web-based viewer for
> mathematical plots with Google maps-style dragging and zooming. I
> stumbled across OpenLayers, and it seems like it might be a good tool
> to use for this.
> I've looked through some of the documentation, but I'm having trouble
> figuring out how to go about setting up a custom data source.
> Is this even feasible? Is OpenLayers the right framework for such a
> viewer, or should I be looking for something else?
> Thanks for any input,
> -Bobby
> Bobby Moretti
> moretti at u.washington.edu
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
