[OpenLayers-Users] Getting all points for a geom?
Guillermo Lopez Mackinnon gmlopez.mackinnon at gmail.com
Mon Dec 8 08:53:19 EST 2008
Hey! Many thanks!
That sounds like a great hint and like the correct approach too :-)!
What should I do with the controls variable? Add it to the layer at creation
time?
For example:
controls = {
featureinfocontrol: new OpenLayers.Control.SelectFeature(myvectorlayer,
{onSelect: featureinfo});
var cities = new OpenLayers.Layer.WFS(
                "Cities",
                "http://localhost:8080/geoserver/wfs",
                {typename: 'topp:cities'},
                    typename: 'cities',
                    featureNS: 'http://www.openplans.org/topp',
                    extractAttributes: true,
                    controls: controls
Is the code above correct? Did I understand correctly or do I have to add
this control to the map as the other controls?
I'll try it out and let you know in case I have any problem. If it works
I'll post the solution.
Guillermo
On Mon, Dec 8, 2008 at 1:30 PM, Adorian Ardelean <mynature at gmail.com> wrote:
> Hi Guillermo,
> Look if you can use:
> *feature.attributes["city_name"]*
> example
> featureinfo = function(feature)
> alert(*feature.attributes["city_name"])*;
> controls = {
> All the best,
> Adorian
> On Mon, Dec 8, 2008 at 12:37 PM, Guillermo Lopez Mackinnon <
> gmlopez.mackinnon at gmail.com> wrote:
>> Thanks for your reply!
>> Actually, I meant the feature attributes like for instance "city_name",
>> "population" and so on. I´d like to display some of them when the user
>> clicks on a feature and since I may have several layers, doing it in the way
>> I explained in my initial post it'll be pretty tedious so I'd say it should
>> be some other way (a correct way) of doing this kind of stuff. Am I right?
>> Thanks again for your help!
>> Guillermo
>> On Mon, Dec 8, 2008 at 11:40 AM, Adorian Ardelean <mynature at gmail.com>wrote:
>>> Hi Nino,
>>> Do you mean all nodes of a polygon? If yes, you could explore Vector
>>> Formats Example in http://openlayers.org/dev/examples/ where is shows
>>> also how you could output coordinates of a feature in various formats.
>>> All the best,
>>> Adorian
>>> On Mon, Dec 8, 2008 at 11:24 AM, Nino Saturnino Martinez Vazquez Wael <
>>> nino.martinez at jayway.dk> wrote:
>>>> How can I extract all points for a geometry?
>>>> http://dev.openlayers.org/releases/OpenLayers-2.7/doc/apidocs/files/OpenLayers/Geometry/Collection-js.html#OpenLayers.Geometry.Collection
>>>> , do I need to call a field directly?
>>>> -Wicket for love
>>>> Nino Martinez Wael
>>>> Java Specialist @ Jayway DK
>>>> http://www.jayway.dk
>>>> +45 2936 7684
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>>> Dr. Adorian Ardelean
>>> coordinator of myNature Project
>>> http://mybiosis.info/nature/portal.php?pagename=firstpage [a Romanian
>>> biodiversity-database]
>>> http://mybiosis.info/nature/portal.php?pagename=adorian [CV]
>>> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081208/8c28ed8f/attachment.html
