[OpenLayers-Users] BUG - WFS.setOpacity() cannot work reliably
Estanislao Gonzalez
estanislao.gonzalez at isst.fraunhofer.de
Mon Dec 8 11:35:29 EST 2008
I couldn't fill a bug for it, and don't have currently the time to find
out why... sorry.
But if someone is kind enough, please do fill it.
The bug is caused because of the multiple inheritance of Layer.WFS
(inheriting from Layer.Vector and Layer.Markers). I presume the
intention is to fall back in case the browser doesn't support vector
rendering.
The method setOpacity for Layer.Markers is different from that of Layer
(which is the parent class of Layer.Vector) and depends on the markers
attribute. If WFS is on vectors (myWFS.isVector == true), the
overwritten setOpacity method tries to access 'markers' which happen to
be empty. And the nasty bugs prevents the rest of the script from
running normally.
The solution might be to decide which of the two methods should be used
(yep, redundant methods... yikes, but inheriting from more than one
class tends to do that). So here is my proposal which seems to run
perfect, at least as far as I could test.
OpenLayers.Layer.WFS.prototype.setOpacity = function(opacity){
if (this.isVector) {
//Sets the opacity to the whole layer
//from OpenLayers.Layer.Vector
if (opacity != this.opacity) {
this.opacity = opacity;
for (var i = 0, len =
this.div.childNodes.length; i < len; ++i) {
var element = this.div.childNodes[i].firstChild;
OpenLayers.Util.modifyDOMElement(element,
null, null, null, null, null, null, opacity);
else {
// Sets the opacity for all the markers.
// from OpenLayers.Layer.Markers
for (var i = 0, len = this.markers.length; i <
len; i++) {
this.markers[i].setOpacity(this.opacity);
As I'm not in the OpenLayers architecture I might have forgotten to do
something, or neglected to take something into consideration. So if
someone is kind enough to point the bug and solution to the right
people, we all will get a better 2.8 version ;-)
Regards,
Estani
Dipl.-Kfm. Estanislao Gonzalez, Fraunhofer-Institut für Software- und Systemtechnik ISST
Location-based Services, Steinplatz 2, 10623 Berlin, Germany
Telefon: +49 (0) 30 / 2 43 06-3 36
mailto:estanislao.gonzalez at isst.fraunhofer.de
www.isst.fraunhofer.de
