[OpenLayers-Users] DrawFeature with callback?
Eric Lemoine eric.c2c at gmail.com
Mon Dec 8 12:04:18 EST 2008
Hi
var e = new OpenLayers.Control.EditingToolbar(...);
for(var i = 0; i<e.controls.length; i++) {
    var c = e.controls[i];
    c.events.on({
       "featureadded": functio(e) {
           alert(e.feature);
Untested.
Cheers,
Eric
2008/12/8, Nino Saturnino Martinez Vazquez Wael <nino.martinez at jayway.dk>:
> Hi again
> What if you want todo the exact same thing with the editing toolbar?
>             map.addControl(new
> OpenLayers.Control.EditingToolbar(vectors,OpenLayers.Handler.Polygon,{'featureAdded':
> serialize}));
> Does not work...
> Adorian Ardelean wrote:
>> Hi Nino,
>> This works ok for me:
>> dosomething = function (feature)
>>       //do something with polygon
>>       alert("yeeehaaa");
>> controls = {
>>   polygon: new
>> OpenLayers.Control.DrawFeature(regions,OpenLayers.Handler.Polygon,
>> {'featureAdded': dosomething})
>> All the best,
>> Adorian
>> On Fri, Dec 5, 2008 at 2:03 PM, Nino Saturnino Martinez Vazquez Wael
>> <nino.martinez at jayway.dk <mailto:nino.martinez at jayway.dk>> wrote:
>>     Okay so I now have this, still not working though:
>>     <html xmlns="http://www.w3.org/1999/xhtml">
>>      <head>
>>       <title>OpenLayers Regular Polygon Example</title>
>>       <script src="http://openlayers.org/api/OpenLayers.js"></script>
>>       <script type="text/javascript">
>>           var map, polygonControl;
>>           OpenLayers.Util.onImageLoadErrorColor = "transparent";
>>           function init(){
>>               map = new OpenLayers.Map('map');
>>                         var wmsLayer = new OpenLayers.Layer.WMS(
>>     "OpenLayers WMS",
>>                   "http://labs.metacarta.com/wms/vmap0?", {layers:
>>     'basic'});
>>               var polygonLayer = new OpenLayers.Layer.Vector("Polygon
>>     Layer");
>>               map.addLayers([wmsLayer, polygonLayer]);
>>               map.addControl(new OpenLayers.Control.LayerSwitcher());
>>               map.addControl(new OpenLayers.Control.MousePosition());
>>               dosomething = function (polygon)
>>                   alert("yeeehaaa");
>>               polyOptions = {sides: 4, callbacks: {'featureAdded':
>>     dosomething}  };
>>               polygonControl = new
>>     OpenLayers.Control.DrawFeature(polygonLayer,
>>     OpenLayers.Handler.RegularPolygon,
>>                                               {handlerOptions: polyOptions
>>                         map.addControl(polygonControl);
>>                         map.setCenter(new OpenLayers.LonLat(0, 0), 3);
>>                         document.getElementById('noneToggle').checked
>>     = true;
>>           function setOptions(options) {
>>               polygonControl.handler.setOptions(options);
>>           function setSize(fraction) {
>>               var radius = fraction * map.getExtent().getHeight();
>>               polygonControl.handler.setOptions({radius: radius,
>>                                                  angle: 0});
>>       </script>
>>      </head>
>>      <body onload="init()">
>>       <h2 id="title">OpenLayers Regular Polygon Example</h2>
>>       <p id="shortdesc">
>>         Shows how to use the RegularPolygon handler to draw features with
>>         different numbers of sides.
>>       </p>
>>       <div id="map" class="smallmap"></div>
>>       <div id="config">
>>                 <ul id="controls"><b>Map Controls</b>
>>               <li>
>>                   <input type="radio" name="type"
>>                          value="none" id="noneToggle"
>>                          onclick="polygonControl.deactivate()"
>>                          checked="checked" />
>>                   <label for="noneToggle">navigate</label>
>>               </li>
>>               <li>
>>                          value="polygon" id="polygonToggle"
>>                          onclick="polygonControl.activate()" />
>>                   <label for="polygonToggle">draw polygon</label>
>>               </li>
>>           </ul>
>>       </div>
>>      </body>
>>     </html>
>>         Hi,
>>         I presume you have to specify the event name somehow. Try
>>         including this:
>>          ...callbacks: {'featureAdded': dosomething}...
>>         All the best,
>>         Adorian
>>         On Fri, Dec 5, 2008 at 12:59 PM, Nino Saturnino Martinez
>>         <mailto:nino.martinez at jayway.dk>>> wrote:
>>            Hi Guys
>>            Im doing a integration for the Apache Wicket framework(
>> http://wicketstuff.org/confluence/display/STUFFWIKI/wicket-contrib-openlayers
>>            ), and want to add some more features. Im looking into
>>         adding the
>>            possibility to draw polygons, however I cant find a example
>>         where
>>            theres
>>            a simple callback involved once the polygon are drawn,
>>         however the api
>>            mentions it's possible.
>>            As you can see from the below code the only thing I need
>>         for this
>>            little
>>            thing to work are the function that calls the alert to be
>>         picked up.
>>            Please say if you want me to elaborate further.
>>             <head>
>>               <script
>>                   function init(){
>>         "OpenLayers WMS",
>>            'basic'});
>>            Layer");
>>                       map.addControl(new
>>                       map.addControl(new
>>            {function(value){alert('yeeeha');}}  };
>>                                                       {handlerOptions:
>>            polyOptions
>>                       document.getElementById('noneToggle').checked =
>>         true;
>>          document.getElementById('irregularToggle').checked =
>>            false;
>>                                                          angle: 0});
>>               </script>
>>             </head>
>>               <p id="shortdesc">
>>         features with
>>               </p>
>>               <div id="config">
>>                       <li>
>>                       </li>
>>                       <li>
>>                       </li>
>>                   </ul>
>>               </div>
>>             </body>
>>            </html>
>>            -Nino
>>            _______________________________________________
>>            Users mailing list
>>            Users at openlayers.org <mailto:Users at openlayers.org>
>>         <mailto:Users at openlayers.org <mailto:Users at openlayers.org>>
>>            http://openlayers.org/mailman/listinfo/users
>>         Dr. Adorian Ardelean
>>         coordinator of myNature Project
>>         http://mybiosis.info/nature/portal.php?pagename=firstpage [a
>>         Romanian biodiversity-database]
>>         http://mybiosis.info/nature/portal.php?pagename=adorian [CV]
>>     -Wicket for love
>>     Nino Martinez Wael
>>     Java Specialist @ Jayway DK
>>     http://www.jayway.dk
>>     +45 2936 7684
>> http://mybiosis.info/nature/portal.php?pagename=firstpage [a Romanian
> -Wicket for love
> Nino Martinez Wael
> +45 2936 7684
> Users mailing list
