[OpenLayers-Users] HTTP protocol with featureserver
Alexandre Dube
adube at mapgears.com
Wed Dec 10 14:58:42 EST 2008
Hi Andreas,
First, many many thanks for your time ! I'm so glad you answered...
Andreas Hocevar wrote:
> I am not sure how the FeatureServer response after a commit looks like.
> To investigate that further, you should set a breakpoint in
> Protocol.Save::onCommit. response.reqFeatures should contain the
> features you commited. response.insertIds should contain the fids
> assigned by FeatureServer, in the same order.
That I did already. response.insertIds never gets populated. It does
with WFST, by the "InsertResult" on handleCommit, but there's nothing
for that with HTTP.
Plus, WFST always uses GML, correct ? So it's ok to use "InsertResult",
but in my example I can actually set the format. So in my opinion it
would be wrong to have Protocol.HTTP handles the results... or if should
be different depending on the format used... I dunno...
About Protocol.Save : I already noticed that I could simply check if
insertIds is empty after this line
var insertIds = response.insertIds || [];
if it's empty, I can just look directly in the response.priv.reponseText
and using a regex I could build an array of IDs, but I know that's not
where that should be. The Save strategy should be standard, not
specific to some formats...
Any more hints ?
> See above.
> I hope this helps. Please report back your findings, since Tim and I
> will be working on finishing the WFS work in the next couple of weeks.
> Regards,
> Andreas.
Alexandre Dubé
Mapgears
www.mapgears.com
