[OpenLayers-Users] HTTP protocol with featureserver
Andreas Hocevar
ahocevar at opengeo.org
Wed Dec 10 16:12:51 EST 2008
Alexandre Dube wrote:
> Andreas Hocevar wrote:
>> Yes, but quite some efforts would be required. Reading the insertIds
>> this is the format's job. Format.GeoJSON does not know about insertIds.
>> The best thing to do here would be to subclass Format.GeoJSON and create
>> e.g. a Format.GeoJSON.FeatureServer. The next thing is that you need a
>> protocol that can handle insertIds. Protocol.HTTP cannot do that, so
>> this would also have to be extended.
>> I am also quite new to the vector behavior stuff, so I might be wrong.
>> But to me it seems that the above should work.
>> Let me know when you need more help, because I have to gain deeper
>> insight into that code anyway and doing it for a purpose other than just
>> looking at it will also make it easier for me.
>> Regards,
>> Andreas.
> Yep, that's exactly what I had in mind.
> Eric suggested to use the protocol.commit() function, but it has the
> same problem ( no fid on new added features ), so I'll have to implement
> one. I'm still trying to figure how to just add function on commit(),
> there's already something for that but I'm missing something because
> when I set one, it replaces what is usually does instead of adding one :
> olWFSRoads = new OpenLayers.Layer.Vector("Roads FS GeoJSON", {
> scales: oMap.getScales(8,10),
> styleMap: oStyleMap,
> strategies: [new OpenLayers.Strategy.BBOX()/*, oSaveStrategy*/],
> protocol: new OpenLayers.Protocol.HTTP({
> url: szFSURL+"/bdga_route_l_arc?format=GeoJSON",
> format: new OpenLayers.Format.GeoJSON(),
> create: function(){alert("foo")} //<-- this gets
> triggered, but no POST is created...
> I'll continue to look deeper and try to understand this.
You can pass a userCallback to the create function if you instantiate
the protocol like that:
url: "yourUrl",
format: OpenLayers.Format.GeoJSON, // needs to read insertFids
options: {
create: {
callback: function(response) {
// your stuff here
scope: yourFunctionScope
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
