[OpenLayers-Users] tilesOrigin distorts feature info on zoom
Christopher Schmidt
crschmidt at metacarta.com
Thu Dec 11 07:43:25 EST 2008
On Thu, Dec 11, 2008 at 12:41:53AM -0800, brizey02 wrote:
> tilesOrigin causes feature info to be off once i zoom in past 1:72k, what is
> causing this?
TilesOrigin is a server side feature of GeoServer. It's not specific to
OpenLayers, and questions may be best directed at the GeoServer
community.
> I removed this witch makes the map work perfectly in firefox but ie does not
> load the page.
I bet that you removed the tilesOrigin parameter, then didn't remove the
',' after tiled, and IE didn't load the map at all. IE doesn't allow
commas as the last item in an object/hash.
Regards,
Christopher Schmidt
MetaCarta
