[OpenLayers-Users] Cluster strategy and extract attributes?
Joanne Cook
j.cook at oxfordarch.co.uk
Thu Dec 11 10:44:52 EST 2008
Hi Chris,
Yes, you're absolutely right I should provide some code:
Ext.onReady(function() {
var mystyle = new OpenLayers.Style({
'pointRadius': "${radius}",
'fillColor': "#ffcc66",
'fillOpacity': 0.8,
'strokeColor': "#cc6633",
'strokeWidth': 2,
'strokeOpacity': 0.8},
{context: {
radius: function(feature) {
return Math.min(feature.attributes.count, 7)+3;
----more code-----
wfs = new OpenLayers.Layer.Vector("OA Sites WFS", {
strategies: [new OpenLayers.Strategy.Fixed(), new OpenLayers.Strategy.Cluster()],
protocol: new OpenLayers.Protocol.HTTP({
url: "http://10.0.10.106/cgi-bin/mapserv900913.cgi?",
params: {
format: "WFS",
service: "WFS",
version: "1.0.0",
request: "GetFeature",
typename: "oasites_wfs",
SRS: "EPSG:900913"},
format: new OpenLayers.Format.GML()
styleMap: new OpenLayers.StyleMap({
"default": mystyle,
"select": {fillColor: "#8aeeef",
strokeColor: "#32a8a9"
Thanks
Jo
Joanne Cook
Senior IT Support and Development
Oxford Archaeology (North)
01524 880212
http://thehumanjourney.net
----- Original Message -----
From: "Christopher Schmidt" <crschmidt at metacarta.com>
To: "Joanne Cook" <j.cook at oxfordarch.co.uk>
Cc: "users" <users at openlayers.org>
Sent: Thursday, 11 December, 2008 15:40:09 GMT +00:00 GMT Britain, Ireland, Portugal
Subject: Re: [OpenLayers-Users] Cluster strategy and extract attributes?
On Thu, Dec 11, 2008 at 03:26:04PM +0000, Joanne Cook wrote:
> Dear All,
> I have implemented a cluster strategy for WFS points on my map, as per
> the example in the documentation. It might just be me, but to get it
> to work at all I had to swap from using OpenLayers.Layer.WFS to
> OpenLayers.Layer.Vector, with a Protocol statement to make up the URL.
> When I tried to add in the "extractAttributes: true" parameter, my
> page didn't display, though it worked fine if I took that statement
> out. However, if I still want to be able to click on a point (when I'm
> down to points representing single sites) and get information, is it
> possible to do that at all? Currently my attributes in the popup just
> show us as "undefined". Was I right to change from Layer.WFS to
> Layer.Vector?
Strategies require the use of Layer.Vector, yes. I don't know where you
added your extractAttributes parameter, but it's most likely that you
need to configure your protocol with a format object ,and in the
creation of that format object, pass the extractAttributes option.
Can you provide code that you have currently, or a link? It is easier to
review a minimal example of the current behavior/problem than it is to
guess how you might be doing things.
Regards,
Christopher Schmidt
MetaCarta
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
