[OpenLayers-Users] wfs feature geometry based on one attribute value
Lehtonen, Mika mika at digikartta.net
Thu Dec 11 11:49:09 EST 2008
Yep,
that'll I do. I was just wondering whether there would be a clever way
to do this, but I guess, because I haven't got any features rendered and
actually extractAttributes is set to false, it's better to stick to that
GetFeature method. Actually my present need is to fetch a single only
geometry and to use its bounding box.
Yeah, I believe also so that GeoServer's CQL-filter allows to just state
attr1=what_you_want, of course in proper syntax.
thanks,
- mika -
Alexandre Dube kirjoitti:
> Well I guess your CQL_FILTER approach looks ok, so you could just
> change it to request a specific feature that has a specific attribute
> value.
> I never used GeoServer but I think the following links could help you
> find what you need :
> http://geoserver.org/display/GEOSDOC/WMS+vendor+parameters
> http://geoserver.org/display/GEOSDOC/WFS+vendor+parameters
> And about my solution, I guess it was good for my example of "city
> search" because I need all of them, but in your case you only need
> what's requested by the user, so it's not really useful to fetch them
> all at first.
> Best regards,
> Alexandre
>>>> I have my data in PostGIS and I mean features that aren't shown in
>>>> my map. Or actually they are shown, but through wms. I am already
>>>> fetching some attributes after geometry comparison through wfs
>>>> GetFeature, but I was wondering whether there would some other ways
>>>> to do that.
>>> Could you share an example of this ?  I would like to see how you do
>>> it.
>>> Alexandre
>> Sure,
>> it ain't no rocket science. I'm using GeoServer and PostGIS. I have
>> about 3000 polygons in my wfs service and I need to get some
>> attributes out of those I choose using wms-layer as a reference. The
>> choosing tool is sort of a buffer tool (choose all features which are
>> entirely or partially inside the circle). First I do the GetFeature.(
>> I'll try to incorporate only the essential parts..)
>> function buffer(e) {                     var url =
>> wfs.getFullRequestString({
>>                SERVICE: 'WFS',
>>                VERSION: '1.0.0',
>>                REQUEST: 'GetFeature',
>>                OUTPUTFORMAT: 'json',
>>                PROPERTYNAME: 'the_geom,attr1',
>>                MAXFEATURES: 1000,
>>                TYPENAME: 'ns:layername',
>>                SRSNAME: 'EPSG:900913',
>>                CQL_FILTER: 'INTERSECT(the_geom,'+ buffergeometry +')'
>>                           "http://host.domain/geoserver/wfs"
>>                OpenLayers.loadURL(url,'',this,bufferUpdate);
>>                Event.stop(e);
>> Then I dig the attributes I need out of the response:
>> function bufferUpdate (response) {
>>                g =  new OpenLayers.Format.JSON();
>>                resp = g.read(response.responseText);
>>                attrdata = new Array();
>>                for (i in resp.features) {
>>                attrdata[i] = resp.features[i].properties.attr1; }
>> I hope I included all the parts needed. Anyway after this I have an
>> array of attributes (attr1) of the chosen geometries. I guess
>> CQL_FILTER is Geoserver specific and JSON isn't mandatory format in
>> wfs compliant server, but of course there could be used standard
>> FILTER and GML output with 'getElementsByTagName' or similar.
>> - mika -
