[OpenLayers-Users] Adding popups to vector features
Eric Lemoine
eric.c2c at gmail.com
Fri Dec 12 02:17:44 EST 2008
Hi Christopher
You could create your own hover feature for that. This control would
use a feature handler internally, just like th select feature control.
You can start from the select feature control and simplify it to the
point where it just creates a feature handler configured with "over"
and "out" callbacks. Hope this is enough information...
Eric
2008/12/10, Heidt, Christopher M. <CHRISTOPHER.M.HEIDT at saic.com>:
> Yep, that's exactly what im doing. thanks
> I know I cant have to select controls open at once, but is there a way
> to add a hover select to that example?
> Basically I need to show an abridged description on hover and a fullout
> verbose description on click.
> -----Original Message-----
> From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
> Sent: Wednesday, December 10, 2008 1:33 PM
> To: Heidt, Christopher M.
> Cc: OpenLayers
> Subject: Re: [OpenLayers-Users] Adding popups to vector features
> On Wed, Dec 10, 2008 at 01:23:20PM -0500, Heidt, Christopher M. wrote:
>> Very valid point.
>> All I was really going for was a popup on select, so for me id
>> probably try to tie cursor position into it.
>> Perhaps that's more like a vector tooltip?
> Right, so your question is "how can I create a popup on selecting a
> feature that is appropriately positioned", which is a different question
> than whether a vector feature should have a createPopup method.
> http://openlayers.org/dev/examples/sundials.html creates a popup in a
> selectfeature callback; It is probably possible to take the evt.xy from
> the select feature callback (I believe I've done that before).
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
