[OpenLayers-Users] cluster does not disappear
Didrik Pinte
lists at dipole-consulting.com
Fri Dec 12 10:40:48 EST 2008
I use the cluster strategy to show trees along streets. When the trees
are clustered, the user can click the cluster so that the map recenters
on the geometries contained in the cluster. It works fine except that
the cluster stays on the map
The onClick code is the following :
function onFeatureClick(feature){
// on feature click : go to tree page if it is a tree
// or recenter on cluster content if it is a cluster
if (feature.attributes.count == 1) {
eval(getTreeLink(feature.attributes.id));
} else {
var e = feature.geometry.getBounds();
for (var j = 0; j< feature.cluster.length; j++) {
e.extend(feature.cluster[j].geometry.getBounds());
map.zoomToExtent(e);
Anybody knows what I can do to make it dissapear ? If I zoom manually on
the cluster, it dissapear correctly.
Thanks
Didrik
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081212/17dae424/attachment.bin
