[OpenLayers-Users] howto regist. featuremodified instead
	onModification ?
    Alexandre Dube
    adube at mapgears.com
    Fri Dec 12 13:17:53 EST 2008
  The onModification function of ModifyControl is deprecated.  How do
you register a featuremodified instead ?
  I've tried this but oFeature is the layer object instead of a feature :
layer.events.register("featuremodified",'', onRoadModification);
function onRoadModification(oFeature) {
    OpenLayers.Console.log("modified", oFeature.id);
I tried ("featuremodified",this.feature, onRoadModification), not
working either.
this could work, but I'm not sure it's the good way to do it.
function onRoadModification(object) {
    oFeature = object.feature;
The old onModification was called with (object.feature), so I suppose
the above solution is the good way, but I just want to be sure.
Any hint ?
Alexandre Dubé
Mapgears
www.mapgears.com
