[OpenLayers-Users] howto regist. featuremodified instead onModification ?
Alexandre Dube adube at mapgears.com
Fri Dec 12 14:19:03 EST 2008
Well, I don't 100% understand.  Using on, what's the use of the scope ?
The following works without scope :
        olWFSRoads.events.on({
            featuremodified: function(o) {
                var oFeature = o.feature;
                OpenLayers.Console.log("modified", oFeature.id);
or the following works also, but scope is still useless here.
                onRoadModification(o.feature);
            scope: this
function onRoadModification(object) {
    var oFeature = object.feature;
In the end, I want to move my OpenLayers demo into MapFish and I want to
use some widgets like the list of features which uses a Modification
control.  It already has its own defined onModification function, so I
have to get rid of mine and register an event instead.  Using one of the
above method should do the trick, I am correct ?
Thanks again for your help,
Alexandre
Eric Lemoine wrote:
> You are correct.
> For information, the second argument to the register method is the
> scope. "this" in the callback will reference the object this scope
> references. Hope I'm clear enough.
> Note that can also use the "on" method:
> layer.events.on({
>    scope: your_scope
> Cheers,
> Eric
> 2008/12/12, Alexandre Dube <adube at mapgears.com>:
>> Hi,
>>   The onModification function of ModifyControl is deprecated.  How do
>> you register a featuremodified instead ?
>>   I've tried this but oFeature is the layer object instead of a feature :
>> layer.events.register("featuremodified",'', onRoadModification);
>> function onRoadModification(oFeature) {
>> I tried ("featuremodified",this.feature, onRoadModification), not
>> working either.
>> this could work, but I'm not sure it's the good way to do it.
>> The old onModification was called with (object.feature), so I suppose
>> the above solution is the good way, but I just want to be sure.
>> Any hint ?
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
