[OpenLayers-Users] Several control for several layers at the same
time
arno974
arnaud.sig at gmail.com
Wed Dec 17 08:13:57 EST 2008
I'm using OL 2.7 and i wondering if it's possible to have several control
for several layers at the same time. For example, in my project i'm using
the Select Control for several layers but i can only select on layer.
I saw in this post
(http://www.nabble.com/Several-selectFeature-control-td20151130.html#a20153141)
that there is a limitation for the control. Only one can be activate at the
same time. Is they're a way or a patch to fix this limitation?
The solution proposed by Eric Lemoine was to regroup all the layers in a
same layer. But due to the way of my project is organize i can't do it in
this way.
Thanks in advance.
Best regards
Arnaud
View this message in context: http://www.nabble.com/Several-control-for-several-layers-at-the-same-time-tp21052904p21052904.html
