[OpenLayers-Users] {'zoomWheelEnabled':false}
Christopher Schmidt crschmidt at metacarta.com
Thu Dec 18 10:53:12 EST 2008
On Thu, Dec 18, 2008 at 04:43:56PM +0100, Didrik Pinte wrote:
> Hi,
> I'm trying to disable the mouse wheel interaction.
> I've followed the navigation control example but it does not work.
> I initialise my map without controls, then I add ScaleLine, PanZoomBar,
> NavToolBar, LayerSwitcher, MousePosition  and KeyboardDefaults
> Finally, I add my Navigation and explicitely call disableZoomWheel() on
> it BUT the zoom wheel stays activated on the loaded map.
You have added two Navigation controls to your map. The NavToolbar
creates a Navigation control (internally).
If you want different behavior of the NavToolbar, you'll need to create
a custom toolbar control -- copying the code from the NavToolbar, and
change the options of the Navigation control in the initialize.
> Is there any interaction between the Navigation and the other controls
> that could force the zoom wheel to stay activated ?
> Thanks
> Didrik
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
