[OpenLayers-Users] Custom Controls
Christopher Schmidt
crschmidt at metacarta.com
Thu Dec 18 13:17:18 EST 2008
On Thu, Dec 18, 2008 at 05:44:23PM -0000, André Matos wrote:
> Hi Guys!
> I am starting on OpenLayers API and I have two questions
> I am studing the controls and I have notice that, theres no API methods or
> API properties in Control type. That means the open layers developers can
> change it, without any advise.
> The way I am doing my controls is this:
> Is this the best way to implement custom controls?
I think so.
> Will OpenLayers
> developers change the not API methods, initialize, draw, destroy or the div
> property defined at Control Class?
I think it's fair to say we won't change any of those. I'll wait for
dissenting opinions before changing the docs.
> description in the Control Class destroy method:
> Method: destroy
> * The destroy method is used to perform any clean up before the control
> * is dereferenced. Typically this is where event listeners are removed
> * to prevent memory leaks.
> But it Is never called. The control is dereferenced at Map.removeControl
> method, and this method does not call control.destroy method
Generally speaking, we try not to .destroy() anything we don't create --
meaning it would be up to application designers to destroy things.
When the map itself is destroyed, we do destroy any control associated
with it -- but removing a control is not equivilant to wanting it
destroyed. Instead, it's a sign that the control should no longer be
visible on the map. The user might then take that same control and addi
t back to the map later.
So, this is just representative of our conservative destruction
philosophy.
Regards,
Christopher Schmidt
MetaCarta
