[OpenLayers-Users] Beginer questions
Joao Duarte joao.c.duarte at co.sapo.pt
Fri Dec 19 10:01:30 EST 2008
Hello,
I’ve recently started using OpenLayers and I have 4 questions:
1.       I’ve been using the “resize” transition effect on my base layer.
However the effect doesn’t occur in every zoom in/out. Am I missing
something or the transition effect still has some issues?
2.       A have many types of data to display over the map. One of those is
KML. In the KML file I want to represent there’s a “GroundOverlay” element
which defines as image to overlap onto the map. I can’t find the support for
this type of elements in the KML parser. Are there any plans for this or
some kind of workaround?
3.       Another type of data I want to display on the map are some district
shapes, defined in GeoJSON. The parser handles it fine and the shapes are
represented on the map: http://img241.imageshack.us/img241/6856/img1vj0.jpg
. However when I zoom in, the shapes of the islands at the left become
visible when they should not, since the islands themselves are not visible
on the map http://img120.imageshack.us/img120/930/img2lt8.jpg . Anyone has
some ideas about what could be the problem?
4.       I’ve tried to use the Cluster strategy when creating a layer of the
type Vector. Is there anyway that I can apply such strategy to the Markers
layer?
Thanks in advance.
Best regards,
João Duarte
 <http://mapas.sapo.pt> http://mapas.sapo.pt
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081219/dd99ab7c/attachment.html
