[OpenLayers-Users] Query Tool?
Semantica jvanulde at nrcan.gc.ca
Tue Dec 23 17:25:05 EST 2008
Hi Bart,
So I am about 80 percent there now:
http://dev.openlayers.org/sandbox/jvanulden/openlayers/examples/extended-layerswitcher.html
The only thing to so now is disable the drag handler on the map when the
user selects the query tool. Any idea on how I can achieve this???
bartvde wrote:
> Hi,
> maybe the following sandbox is informative:
> http://dev.openlayers.org/sandbox/bartvde/wmsgetfeatureinfo/openlayers/examples/featureinfo-control.html
> the proxy is not setup correctly in the sandbox so it won't actually
> work, but if you run it locally with a local proxy.cgi script it should
> do the job.
> Best regards,
> Bart
> Semantica wrote:
>> Hi all,
>> Does anyone have an example of adding a query button to a control panel?
>> I
>> want to add a button that when clicked toggles query mode (e.g. maps
>> single-click event to a function that will do a getFeatureInfo). Clicking
>> again will deactivate query mode.
>> I have the getFeatureInfo working already but am unsure as to how to wire
>> up
>> the controls...
>> Thank you in advance!!!
> Bart van den Eijnden
> OSGIS, Open Source GIS
> bartvde at osgis.nl
> http://www.osgis.nl
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Query-Tool--tp1694415p1695373.html
