[OpenLayers-Users] GML/KML feeds not loading
Michael Angstadt mangstadt at jbisoft.com
Mon Dec 29 12:06:38 EST 2008
Good afternoon,
I'm having trouble getting certain KML and GML feeds to load in
OpenLayers and I wonder if someone can help.  The issue appears in
versions 2.6 and 2.7 of OpenLayers.
Let me start with KML feeds.  The feed taken from the "KML Layer
Example" on the examples section of the OpenLayers website[1] works just
fine.  This feed draws a number of weird shapes in Arizona.  However, I
cannot get another feed, taken from CBSNews' website, to work[2].  One
of my co-workers was able to view this in Google Earth just fine (see
attached screenshot).  Is this feed only compatible with Google Earth?
I searched the bug tracking system and found a ticket that might be
relevant[3].  The ticket states that "the current KML class is a Format
& hence can only deal in Feature.Vector objects".  This seems to explain
why the feed which displays vectors[1] works and the feed which displays
points[2] does not.
So unless my Javascript code is incorrect, it seems like OpenLayers only
has *partial* support for KML feeds.  Is this true?  Is there any reason
why the CBSNews feed should not work in OpenLayers?  Here is the
Javascript code I use to load the KML layer:
map.addLayer(new OpenLayers.Layer.GML(
'CBSNews',
'http://www.cbsnews.com/common/includes/google/cbsnews.kml',
  format: OpenLayers.Format.KML,
  formatOptions:
    extractStyles: true,
    extractAttributes: true,
    maxDepth: 3
I have the identical issue with GML feeds.  Example feeds taken from the
OpenLayers website[4,5] work fine (they draw shapes in France and Canada
respectively).  But a GML feed a co-worker of mine found online[6] does
not.  This co-worker has told me that the feed displays fine in Google
Earth and shows a number of points across the US (I don't have a
screenshot for this unfortunately).
So, is it also true that OpenLayers only has *partial* support for GML
feeds?  Here is my Javascript code for loading a GML layer:
map.addLayer(new OpenLayers.Layer.GML('airports',
'http://examples.oreilly.com/webmapping/ch7/airports.gml'));
Thanks for your help and have a Happy New Year!
-Mike
[1] http://openlayers.org/dev/examples/kml/lines.kml
[2] http://www.cbsnews.com/common/includes/google/cbsnews.kml
[3] http://trac.openlayers.org/ticket/1567
[4] http://openlayers.org/dev/examples/gml/polygon.xml
[5] http://openlayers.org/dev/examples/gml/owls.xml
[6] http://examples.oreilly.com/webmapping/ch7/airports.gml
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081229/86ed2830/google_earth.jpg
