[OpenLayers-Users]  overview map
    matthewsnape
    mattsnape at gmail.com
    Mon Feb  4 12:04:56 EST 2008
I have developed a map and I wish to add an overview control that shows one
of the overlay layers.  The resolututions are set so that the user can not
view the entire extents.  Therefore, I would like the overview map to show a
zoom level a couple of levels higher than the main map control.  However, I
get the following error:
bounds has no properties
http://www.openlayers.org/api/OpenLayers.js
Line 533
The part of the code code is as follows:
var options = {
size:new OpenLayers.Size(200,200),
layers: [tms_50k],
minRatio: 3, maxRatio: 3,
mapOptions : {  maxExtent: new
OpenLayers.Bounds(500000.000000,100000.000000,600000.000000,260000.000000),
units: 'meters',
projection: 'EPSG:27700',
resolutions :
[12.34722222,8.466666667,3.527777778,2.822222222,2.5,1.763888889] }
var overview = new OpenLayers.Control.OverviewMap(options);
Thanks.
View this message in context: http://www.nabble.com/overview-map-tp15269071p15269071.html
