[OpenLayers-Users] fractionalZoom : bug with worldwind layers ?
Andreas Hocevar andreas.hocevar at gmail.com
Mon Feb 4 15:07:45 EST 2008
Jean,
On Mon, Feb 4, 2008 at 8:46 PM, Jean Pommier (IGE) <jean.pommier at ige.fr> wrote:
> Hi,
> Looks like fractionalZoom does not like worldwind layers...
> When fractionalZoom is set to true, i've got a pb with worldwind layers.
> When zooming, worldwind layers' tiles show in pink, as if it couldn't find
> any. Even, apparently, at normal, integer levels of zoom.
As the ND comment for the Map.fractionalZoom property says: this only
works for layers that do not use pre-calculated tiles for specific
resolutions.
You should not use fractionalZoom at all, if your map contains tiled layers.
Regards,
Andreas.
