[OpenLayers-Users] Openlayers.Feature.Vector cloning
Frédéric Junod frederic.junod at camptocamp.com
Thu Feb 7 10:26:45 EST 2008
Bug report with patch available on http://trac.openlayers.org/ticket/1324
regards,
fredj
Le Thu, 7 Feb 2008 09:54:12 -0500,
Christopher Schmidt <crschmidt at metacarta.com> a écrit :
> On Thu, Feb 07, 2008 at 02:37:24PM +0100, François Van Der Biest wrote:
> > Hi list,
> > I'm showing some vector features on my map, which come from a GeoJson file.
> > In this GeoJson, features have an id, which is not a standard attribute ...
> > for instance:
> > "type": "Feature",
> > "id": "1",
> > "geometry": {
> > "type": "Point",
> > "coordinates": [613100, 2003000]
> > "properties": {
> > "post80": "true",
> > "precise": "true"
> > As a result, OL features inherit this id as a "fid" property.
> > For some reason, I have to clone these features.
> > I was surprised to see that "fid" property is not copied (it becomes "null"
> > in the cloned feature).
> > The reason lies around line 100 in Vector.js :
> > * Method: clone
> > * Create a clone of this vector feature. Does not set any non-standard
> > properties.
> > I guess I have no other solution to move the id parameter inside the geojson
> > "properties" object.
> Well, no, that's not exactly true:
> 1. When you clone a feature, you have a reference to both features:
>  var f = feat.clone();
> You can then set the fid yourself:
>   f.fid = feat.fid;
> However, I don't consider the fid a 'non-standard property', which is
> how OL treats the 'id' property. Since we kinda wrote the spec and the
> reference implementations, calling 'id' non-standard is just silly: 'not
> required' possibly, but not 'non standard': I'd have no problem with a
> patch that added .fid cloning to Features.
> Regards,
Frédéric Junod
Camptocamp SA
