[OpenLayers-Users] boundaries of lineString
Pierre GIRAUD bluecarto at gmail.com
Mon Feb 11 07:09:47 EST 2008
Can you help us understand how you create your "linestring with
4points and obtain a polygon with 8 vertices" by providing a snippet
of code ?
Regards,
On Feb 11, 2008 11:53 AM, Rupesh M G <RupeshM at ibsplc.com> wrote:
>         Thank you for the reply. But I think it is not correct.
> For example, if I draw the linestring with 4 points, I'm able to see a
> polygon with 8 vertices.
> But if I print the components.length of the linestring, it just says 4.
> I tried it with the example in the url
> http://openlayers.org/dev/examples/vector-features.html
> Regards,
> Rupesh
>  "Pierre GIRAUD" <bluecarto at gmail.com>
> 02/11/2008 03:58 PM
> To
> "Rupesh M G" <RupeshM at ibsplc.com>
> cc users at openlayers.org
> Subject Re: [OpenLayers-Users] boundaries of lineString
> It should be quite easy because geometry like lineString and Polygon
>  are composite geometries.
>  For example, a OpenLayers.LineString has a 'components' property which
>  is an array of OpenLayers.Points.
>  That way, you can get all the vertices using a loop like following :
>  for(var i=0; i <= thelinestring.components.length; i++) {
>     // do something with thelinestring.components[i] which is an OL point
>  Regards,
>  Pierre
>  On Feb 11, 2008 9:02 AM, Rupesh M G <RupeshM at ibsplc.com> wrote:
>  > Hi,
>  >         I'm working on an application about roads. There I need to mark a
>  > part of the road, and execute some query.
>  > My user will click a set of points to form a sequence of lines passing
>  > through the center of the road, because there can be bends in the road.
>  > I plan to draw a lineString going through these points. Using a bigger
>  > strokeWidth, I can show it like a road (or like a filled polygon).
>  > Is there any way to get the vertices of that polygon?
>  > Thanks & Regards,
>  > Rupesh
>  >  DISCLAIMER:
>  >  "The information in this e-mail and any attachment is intended only for
> the
>  > person to whom it is addressed and may contain confidential and/or
>  > privileged material. If you have received this e-mail in error, kindly
>  > contact the sender and destroy all copies of the original communication.
> IBS
>  > makes no warranty, express or implied, nor guarantees the accuracy,
> adequacy
>  > or completeness of the information contained in this email or any
>  > and is not liable for any errors, defects, omissions, viruses or for
>  > resultant loss or damage, if any, direct or indirect."
>  > _______________________________________________
>  > Users mailing list
>  > Users at openlayers.org
>  > http://openlayers.org/mailman/listinfo/users
>  DISCLAIMER:
>  "The information in this e-mail and any attachment is intended only for the
> contact the sender and destroy all copies of the original communication. IBS
> makes no warranty, express or implied, nor guarantees the accuracy, adequacy
> or completeness of the information contained in this email or any attachment
