[OpenLayers-Users] Edit a "freehand polygon"
Eric Lemoine eric.c2c at gmail.com
Tue Feb 12 11:40:54 EST 2008
Tim, what kind of advanced geometry ops are you thinking of? Are you
referring to drawing functionalities? Anyway this makes me think of
the addins we're talking about. This lib could be an OL addin. Thx.
Eric
2008/2/12, Tim Schaub <tschaub at openplans.org>:
> Hey-
> Swärd Mårten wrote:
> > Hello!
> > I need some functionality that makes it possible to edit the points in a
> > freehand drawn polygon. I know that it's tecnicaly possible to do this
> > but in real life the edit function, as I know it, is very time
> > counsuming to use due to the many points that has to be modified. The
> > two questions that I have are as follows:
> > A) Is it possible to change the edit function so that when you edit one
> > point the naigbor points follows.. And so to say smoothen the curve of
> > the edited point relative to the rest of the points..
> > B) If the answer is a big NO on A. =) Is it possible to reduce the
> > number of points that is drawn when using the freehand mode?
> This would be an easy modification.  The draw feature control could take
> a tolerance property in the handlerOptions and addPoint would only get
> called in freehand mode when the tolerance was met.
> > B II) Or is it possible to reduce the number of points on a polygon
> > after you have drawn it?
> This would require a simplify (Douglas Peucker style) method for
> geometries.  If there is interest in building a library of more advanced
> geometry operations client-side, it might do well as a compliment to
> OpenLayers (not in OL itself).  I'm interested in this.
> Tim
> > Best regards: Mårten
> > *Mvh:*
> > Mårten Swärd
> > Systemutvecklare/Webbutvecklare, ITs
> > SMHI, Sveriges Meteorologiska och Hydrologiska Institut
> > Tel: +46 11 495 8469
> > !DSPAM:4033,47b03037265381431913854!
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Users mailing list
