[OpenLayers-Users] How do you represent multiple layers in a MapServer Query
David H. McCoy davidhmccoy at COX.NET
Tue Feb 12 16:54:07 EST 2008
A variation on your theme worked. I put the multiple layers in the URL
this
http://localhost:8085/cgi-bin/mapserv.exe?map=/ms4w/apps/app/test.map&layer=states_poly&layer=states_line&mode=map
seems to equal this
var loadedMap = new OpenLayers.Layer.MapServer( "OpenLayers WMS",
"http://localhost:8085/cgi-bin/mapserv.exe?layer=states_poly&layer=states_line",
{map: '/ms4w/apps/app/test.map', mode:'map', format: 'png',
transparent:'false'},
 {layers: 'basic'},
{gutter: 15});
Thanks!
Linda_Rawson wrote:
> I think you need to change it to something like this:
> "http://localhost:8085/cgi-bin/mapserv?map=/ms4w/apps/app/test.map",
> {layers: states_poly,states_line},
> {buffer: 0});
> Linda
> On Feb 12, 2008 12:54 PM, David H. McCoy <davidhmccoy at cox.net> wrote:
>> I have this
>> And I want this
>> "http://localhost:8085/cgi-bin/mapserv.exe",
>> {map: '/ms4w/apps/app/test.map, layer:'states_poly,states_line',
>> mode:'map',
>> format: 'png', transparent:'false'},
>> {layers: 'basic'},
>> {gutter: 15});
>> But it doesn't display. If you want to have multiple occurrances of the
>> same
>> param, but different values, how is this represented?
>> View this message in context:
>> http://www.nabble.com/How-do-you-represent-multiple-layers-in-a-MapServer-Query-tp15441564p15441564.html
>> Sent from the OpenLayers Users mailing list archive at
>> Nabble.com<http://nabble.com/>
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Linda Rawson
> Users mailing list
View this message in context: http://www.nabble.com/How-do-you-represent-multiple-layers-in-a-MapServer-Query-tp15441564p15444101.html
