[OpenLayers-Users] Coordinates systems transformations?
David E. Reksten der at dod.no
Wed Feb 13 09:36:46 EST 2008
This is how I reproject LL to UTM32:
    var destProj = new Proj4js.Proj(map.getProjection()); // Euref89 UTM32
    var sourceProj = new Proj4js.Proj("EPSG:4326"); // WGS84 LonLat
    var position = new OpenLayers.Geometry.Point(lon, lat);
    Proj4js.transform(sourceProj, destProj, position);
Thereafter, position.x and position.y will contain the reprojected coordinates.
Using trunk versions of OL and Proj4js. Hope this helps.
.david
On 13/02/2008, Andrea Maschio <andrea.maschio at gmail.com> wrote:
> Hi all, I suppose that the method Bounds.transform(ProjA, ProjB)
> should transform the coordinates between differents EPSG codes.
> Now I was trying this:
>             var p = bounds
>              console.log(p)
>              p = bounds.transform(new OpenLayers.Projection("EPSG:
> 900913"), new OpenLayers.Projection("EPSG:3003"))
>              console.log(p)
> But p has always the same coords. Btw I am working in a projected
> layer (projected from 3003 to 900913) and my wfs layers are ok, but
> being my coords in the Gauss Boaga metric system, I cannot get them
> correctly trying for example a GetFeatureInfo call using a BBOX.
> Shall I perform a linear translation of the coordinates?
> Thanks
> Andrea Maschio
> http://www.superandrew.it
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
