[OpenLayers-Users] [OpenLayers-Dev] New, sexy, popups -- I need your help! -- GIMP/Inkscape users?
Erik Uzureau euzuro at gmail.com
Mon Feb 18 11:02:55 EST 2008
Actually, reading it over again, it looks like you were looking at
pierre's original version of this
effort. The latest version is in my sandbox, here:
http://dev.openlayers.org/sandbox/euzuro/pop/examples/framedPopups.html
...and I have replaced that iteration, so it should work correctly.
Please do let me know if you find some problems.
Erik
On Feb 18, 2008 9:53 AM, Erik Uzureau <euzuro at gmail.com> wrote:
> Thanks Rupert! I'll change that right away
> erik
> On Feb 18, 2008 6:20 AM, Rupert de Guzman <rndguzmanjr at gmail.com> wrote:
> > Hi Erik,
> > [1] Demo is really nice.
> > [2] I downloaded
> > (http://dev.openlayers.org/sandbox/camptocamp/FramedPopups/lib/OpenLayers/Popup/FramedBubble.js
> > ) and tested but it did not work for my OpenLayers + ExtJS app. The
> > array problem bit me. Just a note to others who may encounter the same
> > issue.
> > for (var i in blocks) {
> > should be
> > for (var i = 0; i < blocks.length; i ++){
> > Regards,
> > Rupert
> > On Feb 15, 2008 4:42 PM, Erik Uzureau <euzuro at gmail.com> wrote:
> > > Dear Dev and Users,
> > > I have been working the last week or so on getting a new style of
> > > openlayers popups coded and
> > > up to speed.
> > > The original version was developed and graciously contributed by the
> > > folks at CloudAmber.
> > > Two weeks ago, the good and noble Pierre Giraud took the CloudAmber
> > > code and some code
> > > worked on by the amazing people at TOPP, smooshed them together into
> > > the following demo:
> > > http://dev.openlayers.org/sandbox/camptocamp/FramedPopups/examples/framedPopups.html
> > > ...which was an amazing job and the real catalyst in this whole situation.
> > > At the TOPP coding bunker, I took this sandbox, played around with it
> > > a little bit, and came up
> > > with a design that allowed us all the functionality of the above two
> > > revisions, plus:
> > > * inherits from OpenLayers.Popup.Anchored (instead of re-implementing
> > > a ton of functions)
> > > * bubbles up the 'autoSize' and 'panIntoView' functions to the base
> > > Popup class so that everyone
> > >  can use them
> > > and finally
> > > * allows the popup to be framed in all four relative directions (tl,
> > > tr, bl, br) by merely adding some
> > >   new framing code.
> > > The last bit here is where I've reached the limits of my own
> > > knowledge. For whatever reason, I
> > > have repeatedly been unsuccessful at producing an alpha-layered image,
> > > despite valiant efforts.
> > > Therefore, my killer demo of the new, sexy popup looks like this:
> > > The problem, then, is that this image:
> > > http://trac.openlayers.org/browser/sandbox/euzuro/pop/img/cloud-popup-relative.PNG
> > > is not properly alpha-ized.
> > > And so I ask your help. Is there anyone out there who could help me to
> > > re-alpha-ize the image?
> > > There will be some tricky issues with the shadows, and perhaps it
> > > would be easier to start with
> > > this original one:
> > > http://trac.openlayers.org/browser/sandbox/camptocamp/FramedPopups/img/popup.png
> > > ..and then add the three new stems yourself.
> > > Anyways, hopefully this email isn't already too long that anyone will
> > > actually read it. If you think
> > > you could help me, please drop me a line.
> > > Best,
> > > Erik
> > > _______________________________________________
> > > Dev mailing list
> > > Dev at openlayers.org
> > > http://openlayers.org/mailman/listinfo/dev
