[OpenLayers-Users] OpenURL abort
Eric Lemoine eric.c2c at gmail.com
Tue Feb 19 13:02:54 EST 2008
Hi Guillaume. Are you talking about loadURL?  I can't check it right
now (am on a mobile) but iirc you can call abort on the object
returned by loadURL. Eric
2008/2/19, Guillaume Sueur <guillaume.sueur at neogeo-online.net>:
> Hi,
> Is there a way to stop an OpenURL method before having any response ?
> I've tried several ways from the docs :
> request.transport.abort(); for example, but without success.
> Any hint ?
> By the way, I discovered there were two different versions of the api
> doc online :
> http://dev.openlayers.org/docs/files/OpenLayers-js.html
> http://dev.openlayers.org/apidocs/files/OpenLayers-js.html
> The main page aims to the second one, which is less documented than the
> first. OpenURL for instance is not documented in
> Is that done on purpose ?
> Thanks,
> Guillaume
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
