[OpenLayers-Users] loadURL: abort
Guillaume Sueur
guillaume.sueur at neogeo-online.net
Thu Feb 21 02:45:30 EST 2008
this one : http://www.openlayers.org/api/OpenLayers.js
I presume it is the trunk version isn't it ?
What you say about the request object matches with what I've read in the
doc effectively. I'm going to try your second way. Thanks.
Guillaume
Eric Lemoine a écrit :
> On Tue, Feb 19, 2008 at 10:49 PM, Guillaume Sueur
> <guillaume.sueur at neogeo-online.net> wrote:
>> hmm, just tried :
>> AjaxTransfert = OpenLayers.loadURL("proxy.py?nom=" +
>> f.attributes["nom"],"",null,getDetails);
>> AjaxTransfert is always undefined as the loadURL function doesn't seem
>> to return anything.
> What OL version are you using? In trunk OpenLayers.loadURL does return
> an object with a transport property on which you can call abort. If
> the version you're using doesn't have that you can probably use that
> instead:
> var request = new OpenLayers.Ajax.Request(url);
> and then do request.transport.abort().
> Hope this helps,
> Eric
Guillaume SUEUR
