[OpenLayers-Users] vectors atop of GoogleMaps in FF
Maria Panagou snowdrop at ath.forthnet.gr
Sun Feb 24 19:37:44 EST 2008
hello,
I have a similar situation here, where my wfs features don't align correctly
with a Google map. Moreover I have a mousedown event on my wfs through which
some attributes are shown on the right hand of the map. When I zoom with the
zoombar (one by one zoomlevel), mousedown event works nice but if I zoom
with a window tool I get an error from element.js saying
geometry has no properties
http://gaia.dbnet.ece.ntua.gr/OpenLayers-2.5/lib/OpenLayers/Renderer/Elements.js
Line 113
you can checkout the behavior in
http://gaia.dbnet.ece.ntua.gr/mpanagou/Query results template_test.html
I tried using Spherical Mercator example to fix these problems but I get the
message in firebug:
OpenLayers.Projection is not a constructor
for the line :
 map = new OpenLayers.Map( 'map' ,
            {projection: new OpenLayers.Projection("EPSG:900913"),
I am using OL 2.5
Any help greatly appreciated !
Maria
If you're to display vector geometries atop a google layer, you'll
need to use SphericalMercator - see
<http://trac.openlayers.org/wiki/SphericalMercator>.
View this message in context: http://www.nabble.com/vectors-atop-of-GoogleMaps-in-FF-tp15647629p15672008.html
