[OpenLayers-Users] WFS layers loaded are not visible
Alessio Di Lorenzo alessio.dilorenzo at gmail.com
Tue Feb 26 15:35:20 EST 2008
Hi list,
I have a problem with openlayers 2.5 and WFS layers generated from
umn-mapserver.
The WFS service is running and serving the layers properly (I tested it
with qgis and udig) but when I try to load the wfs layer in my OL
application, even if it doesn't give errors, it is "invisible". I can
see only the layer title inside the switcher...
Where is the problem?
I copied the proxy.cgi python script from the OL example directory to
the /usr/lib/cgi-bin/ directory (I'm using apache2 with the mod_python
under ubuntu 7.10) and when I type the url
http://localhost/cgi-bin/proxy.cgi in firefox it opens the openlayers
homepage. So I suppose that my proxy is configured properly.
This is my OL script code:
<script type="text/Javascript">
    var map;
    function init(){
            OpenLayers.ProxyHost="/cgi-bin/proxy.cgi/?url= ";
        var bounds  =  new OpenLayers.Bounds(
            396832.88592716516, 4624189.584054877,
                    447059.93946227664, 4690229.517719225
            ); //minX,minY,maxX,maxY values
        var options = {
            //controls: [],
            maxExtent:bounds,
            maxResolution: 'auto',
            projection: "EPSG:32633",
            units:'m'
        map = new OpenLayers.Map('map', options);
        var comuni = new OpenLayers.Layer.WFS(
            "Comuni",
 "http://localhost/cgi-bin/mapserv?map=/var/www/wfs/wfs.map&",
                typename:'comuni',
                extractAtrributes:true
            },{ isBaseLayer:true }
        map.addLayer(comuni);
    map.zoomToExtent(bounds);
          map.addControl( new OpenLayers.Control.KeyboardDefaults());
          map.addControl( new OpenLayers.Control.LayerSwitcher() );
          map.addControl( new OpenLayers.Control.MousePosition ({div:
$('mapinfo')}) );
</script>
thx in advance for your help
alessio
