[OpenLayers-Users] Mercator coordinates mismatch (informationfreeway.org and Freemap)
Nick Whitelegg nick at hogweed.org
Sat Jan 5 05:04:45 EST 2008
Hello everyone,
Freemap has been Mercator for a while now, but has used its own zoom levels
rather than the standard Google zoom levels. By using code from
informationfreeway.org, I have now converted Freemap to use the Google zoom
levels and tiling scheme, but I'm now getting a mismatch in the Mercator
coordinates used compared to previously.
Previously, the mercator coordinates (-85000, 6595000) corresponded to
Fernhurst, West sussex, UK but (as you can see at http://www.free-map.org.uk)
they now correspond to Lavant, some 15 miles south.
The code I previously used to convert from latlon to mercator is a standard
algorithm found on the web and is at
http://www.free-map.org.uk/freemap/javascript/lib/converter.js
(look in the Mercator section)
The OpenLayers code I now use to set up the map is the same as that in
informationfreeway.org, and can be found at
http://www.free-map.org.uk/freemap/javascript/mapnik/init.js
The markers overlays are using the old code, so the markers you see *are* the
Fernhurst area ones.
Any ideas what might have gone wrong?
Thanks,
Nick
