[OpenLayers-Users] MediaWikia
Erik Uzureau erik.uzureau at metacarta.com
Tue Jan 8 18:31:08 EST 2008
Robert,
Would it be OK with you if I add a link to this project on the
http://trac.openlayers.org/wiki/Gallery
Erik
On 1/8/08, Robert J Becraft <castlewrks at hughes.net> wrote:
> Erik,
> Yes, it is up at:
> http://www.metaphaze.com/AvalonWikia/index.php5?title=AvalonMap
> All the layers work and the Semantic markup on the country pages
> provides some junk to come up when you click on the markers. Matt was
> great help in getting it to work.
> Robert.
> Erik Uzureau wrote:
> > Hi Robert,
> > Just a quick note... did you ever manage to get this working?
> > I'm hunting for more examples to help people use OpenLayers
> > in different contexts..
> > Erik
> > On 11/3/07, Robert J Becraft <castlewrks at hughes.net> wrote:
> >> Matt Williamson wrote:
> >>> Robert,
> >>> I'm the author of the extension Christopher mentioned (thanks!). Yes,
> >>> check it out, and also the demo wiki at http://s89238293.onlinehome.us/w/
> >>> If you need any help, let me know. The extension also relies on
> >>> another MediaWiki extension called Semantic MediaWiki, which I highly
> >>> recommend anyway. Currently it requires version SMW 0.7, but I've
> >>> officially started work on the modifications necessary to make it work
> >>> with SMW 1.0--I hope to have the update out by the end of November or so.
> >>> Let me know if you have any questions or need any help with it!
> >>> -Matt
> >> Hello Matt,
> >> I got the simple example up and running... I'm now trying to understand
> >> your documentation and convert my map at
> >> http://www.metaphaze.com/Avalon/AMII_world_map.htm to my wiki page.  I
> >> think I blew a gasket trying to follow the documentation.
> >> You have (I believe), two different components mixed together in your
> >> descriptions... part of the setup requires an understanding of the
> >> Semantic_MediaWiki extension and the second part is how your extension
> >> uses that setup to do its part of putting the map together and adding
> >> the elements.
> >> It would be a great help if you could walk me through this process once
> >> so that I can get the gist of it.
> >> Regards,
> >> Robert J Becraft
> >> _______________________________________________
> >> Users mailing list
> >> Users at openlayers.org
> >> http://openlayers.org/mailman/listinfo/users
