[OpenLayers-Users] TileCache works when used through wms layer
but not as a TileCache Layer
Erik Uzureau
erik.uzureau at metacarta.com
Thu Jan 10 14:49:26 EST 2008
Hi Brent, thanks for this patch... it looks like a good fix. Do you
think you could turn this into a ticket? I think this is something we
should have in OpenLayers.
E
On 1/10/08, Brent Pedersen <bpederse at gmail.com> wrote:
> here's a patch that fixes that. i just checked the code in Layer.py
> from tilecache to see what it did.
> svn diff TileCache.js
> Index: TileCache.js
> --- TileCache.js (revision 5710)
> +++ TileCache.js (working copy)
> @@ -103,8 +103,8 @@
> var res = this.map.getResolution();
> var bbox = this.maxExtent;
> var size = this.tileSize;
> - var tileX = Math.floor((bounds.left - bbox.left) / (res * size.w));
> - var tileY = Math.floor((bounds.bottom - bbox.bottom) / (res * size.h));
> + var tileX = Math.round((bounds.left - bbox.left) / (res * size.w));
> + var tileY = Math.round((bounds.bottom - bbox.bottom) / (res * size.h));
> var tileZ = this.map.zoom;
> * Zero-pad a positive integer.
> On Jan 10, 2008 10:23 AM, Erik Uzureau <erik.uzureau at metacarta.com> wrote:
> > Hi everyone... Lance is still stuck on this. Can anyone help?
> > Here is an updated email that he's sent. Notice how there is a
> > stripe of duplicated tiles on the lefthand side... seems strange.
> > http://www.dyasdesigns.com/croatia/zagrebopenerror.htm
> > -e
> > On 12/9/07, Lance Dyas <lancelot at inetnebr.com> wrote:
> > > To give a little more clue the most obvious error is
> > > TileCache Layer is doubling a Stripe of the tiles on left side at the
> > > outer most zoom
> > > http://www.dyasdesigns.com/croatia/zagrebopen2.htm
> > > after zooming in some of the top row(s) of tiles are being repeated
> > > Lance Dyas wrote:
> > > > Works great as a WMS but and through TileCache but not as TileCache Layer
> > > > here it is as a WMS
> > > > http://www.dyasdesigns.com/croatia/zagrebopen.htm
> > > > but switching to a TileCache.... layer does some wierd things.. really
> > > > wierd things?
> > > > _______________________________________________
> > > > Users mailing list
> > > > Users at openlayers.org
> > > > http://openlayers.org/mailman/listinfo/users
> > > Users mailing list
> > Users mailing list
