[OpenLayers-Users] TileCache works when used through wms layer but not as a TileCache Layer
Christopher Schmidt crschmidt at metacarta.com
Fri Jan 11 08:17:32 EST 2008
On Thu, Jan 10, 2008 at 11:51:27PM -0600, Lance Dyas wrote:
> The fix is great and the tilecache layer is working nicely ... but isnt
> there always a but...
> this is probably an easy one.. ;-) the overview map now isnt recognising
> the
> layer name properly in the urls it requests...
> http://www.dyasdesigns.com/tiles/%5Bobject%20Object%5D/08/000/000/000/000/000/000.png
> http://www.dyasdesigns.com/croatia/zagrebopen2.htm
Without looking at your code, it sounds like you've got an object where
a string is expected. Might double check that you're sending the right
parameters.
Regards,
Christopher Schmidt
MetaCarta
