[OpenLayers-Users] add, remove base layers depending on zoom, change baselayer
Maria Panagou snowdrop at ath.forthnet.gr
Sun Jan 13 13:47:14 EST 2008
I'm trying to display a different base layer, depending on zoom levels. I use
the following code:
 map.events.register("zoomend", map, function() {
			if (map.getZoom()>0) {
			   if (map.getNumLayers()<5) {
		  		 map.addLayers([satellite, hybrid]);
          		 //map.setBaseLayer(satellite]);
          		map.removeLayer(nomoi);
			else
			map.removeLayer(satellite);
			map.removeLayer(hybrid);
			map.addLayer(nomoi);
the above works well when you zoom in and out the map, but if you get to the
extents of the map (zoomlevel:0) when else code executes, then if you try to
zoom again in the map, the code stops working and I see in Firefly that the
problem is:
this.pane has no properties
[Break on this error]  this.pane.style.zIndex =
parseInt(this.div.style.zIndex) + 1;
moreover when I try changing the baseLayer as well with
this works but the whole behavior of layer switcher is altered. I can't no
longer switch between different baselayers from layer switcher. when i click
on a layer, the whole map pans
help please!
View this message in context: http://www.nabble.com/add%2C-remove-base-layers-depending-on-zoom%2C-change-baselayer-tp14789355p14789355.html
