[OpenLayers-Users] Possible pink tile fix
Ben Brehmer
bbrehmer at refractions.net
Mon Jan 14 12:15:43 EST 2008
Eric Lemoine wrote:
>On Jan 11, 2008 7:12 PM, Ben Brehmer <bbrehmer at refractions.net> wrote:
>>Hello all,
>>I just wanted to throw this out there as it might be useful to others;
>>We'd been having some problems with pink tiles, even with
>>IMAGE_RELOAD_ATTEMPTS set to a large number (10). The tile reload would
>>max out and the tile still wouldn't load properly in IE6 & 7. But adding
>>a dynamic dummy parameter to the problem images' URL seems to have
>>solved the problem.
>>In the Util.js::onImageLoadError() function we simply modify the src of
>>the tile:
>>var tmp_src = this.src;
>>this.src = tmp_src+"&retry="+this._attempts;
>>This allows you to monitor how many times an image fails to load from
>>your server logs as well.
>Ben,
>Thanks for sharing this thing. Was your problem related to some cache
>effect in IE?
>Eric
Eric,
I can't say for certain, but I have a suspicion that IE is caching
failed images and not reloading them properly. Changing the URL seems to
cause IE to register that this is a new image. But the key seems to be
the dynamic URL. I've modified the 'alt' attribute in the past which
seemed to work, but less effectively.
Ben
