[OpenLayers-Users] Pink Tile Killing Me
Lee Keel lee_keel at trimble.com
Mon Jan 14 16:31:36 EST 2008
Well it turns out that I can not even use this as a smoke-and-mirrors work around because i have some layers that won't display at all.  Not even in ff.  When I use the URL from firebug, I am still getting the "The specified CGI application misbehaved by not returning a complete set of HTTP headers." error.  I currently have OpenLayers.IMAGE_RELOAD_ATTEMPTS = 5.  I have set it to as high as 20.  Any ideas.  I am really behind the 8 ball here.
-LK
From: users-bounces at openlayers.org on behalf of Lee Keel
Sent: Mon 1/14/2008 2:12 PM
To: Andrew de klerk; users at openlayers.org
Subject: Re: [OpenLayers-Users] Pink Tile Killing Me
you are right that its not a solution, but it is enough for me to tell them I have something there, and I can work on the actual solution.  Thanks for the tip!!!
From: users-bounces at openlayers.org on behalf of Andrew de klerk
Sent: Mon 1/14/2008 1:42 PM
To: users at openlayers.org
This is definately not a solution to the reason why the tiles are coming up
pink...but the following code makes it look less "error-like"
OpenLayers.Util.onImageLoadErrorColor = "transparent";
Andrew
Arnd Wippermann wrote:
> Hi,
> I have the same problem with IE and OL. When IE failed to load a tile, it
> shows the pink background. Then after some attempt(s) the tile will load,
> but the pink background don't vanish. I use png as output format, but I
> have
> also tried with gif. But it is the same behaviour.
> http://www.panoramio.com/photo/7120030
> Mit freundlichen Grüssen
> Arnd Wippermann
> http://gis.ibbeck.de/ginfo/
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von Lee Keel
> Gesendet: Samstag, 12. Januar 2008 22:31
> An: users at openlayers.org
> Betreff: [OpenLayers-Users] Pink Tile Killing Me
> Hello list.  I am having a problem with pink tiles.
> Configuration:
>  I am using OL 2.5, that I download from the link at
> http://www.openlayers.org/api/OpenLayers.js, with ms4w beta from Sept 10.
> Running against Postgres.
> Problem:
> I am getting a pink tile from my wms layers in ie, but the problem is that
> they show at different times.  Once the pink tile turns on for that layer,
> its always there.  So for example, one of the layers the pink tile comes
> on
> when zoomed to max extents, any other resolution for that layer returns
> data
> just fine.  But once you have zoomed to max extents and get the pink tile,
> if you zoom in, the pink tile is there but there is also data.
> What I have Tried:
> The layer has no max extents in the map file, nor a max extent when layer
> is
> added to OL.  I have set all the resolutions and I have removed all the
> resolutions.  I have changed all sorts of settings, but can't seem to find
> the problem.  I have a sample application, that doesn't use ol.  I have
> tested that the data does render through this sample app, so I know the
> data
> is coming from mapserver just fine.
> I am open to any and all recommendations.  I was suppose to have this
> completed yesterday, but this is my last hurdle.  Granted it is one big
> hurdle.
> Thanks in advance,
> Lee
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://www.nabble.com/Pink-Tile-Killing-Me-tp14779152p14811157.html
Users mailing list
Users mailing list
