[OpenLayers-Users] Pink Tile Killing Me
Ben Brehmer bbrehmer at refractions.net
Tue Jan 15 19:33:39 EST 2008
A screen shot would help at this point. Sounds unlikely that the blurred
lines are related to the Pink Tiles.
Ben
Lee Keel wrote:
>I am not sure if these have any part of what is going on with the big pink tile, but I have found some new information and I am trying to provide as much as I can until maybe someone has an idea.
>I am getting some blurred lines from my wms layers at the bottom of the map.  Also, I have found that I use the group name for all of these themes and add the group as 1 single layer, then everything displays correctly.
>I have upgraded my ms4w to 226 instead of the beta; I have added the temprorary fix from the "Possible Pink Tile Fix" chain; I have played around with all of the settings for a layer, but I have yet to fix the pink tile nor the blurred lines.
>I am open to any suggestions that any one has.
>Thanks,
>Lee
>________________________________
>From: users-bounces at openlayers.org on behalf of Lee Keel
>Sent: Mon 1/14/2008 3:31 PM
>To: users at openlayers.org
>Subject: Re: [OpenLayers-Users] Pink Tile Killing Me
>Well it turns out that I can not even use this as a smoke-and-mirrors work around because i have some layers that won't display at all.  Not even in ff.  When I use the URL from firebug, I am still getting the "The specified CGI application misbehaved by not returning a complete set of HTTP headers." error.  I currently have OpenLayers.IMAGE_RELOAD_ATTEMPTS = 5.  I have set it to as high as 20.  Any ideas.  I am really behind the 8 ball here.
>-LK
>Sent: Mon 1/14/2008 2:12 PM
>To: Andrew de klerk; users at openlayers.org
>you are right that its not a solution, but it is enough for me to tell them I have something there, and I can work on the actual solution.  Thanks for the tip!!!
>From: users-bounces at openlayers.org on behalf of Andrew de klerk
>Sent: Mon 1/14/2008 1:42 PM
>This is definately not a solution to the reason why the tiles are coming up
>pink...but the following code makes it look less "error-like"
>OpenLayers.Util.onImageLoadErrorColor = "transparent";
>Andrew
>Arnd Wippermann wrote:
>>Hi,
>>I have the same problem with IE and OL. When IE failed to load a tile, it
>>shows the pink background. Then after some attempt(s) the tile will load,
>>but the pink background don't vanish. I use png as output format, but I
>>have
>>also tried with gif. But it is the same behaviour.
>>http://www.panoramio.com/photo/7120030
>>Mit freundlichen Grüssen
>>Arnd Wippermann
>>http://gis.ibbeck.de/ginfo/
>>-----Ursprüngliche Nachricht-----
>>Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
>>Auftrag von Lee Keel
>>Gesendet: Samstag, 12. Januar 2008 22:31
>>An: users at openlayers.org
>>Betreff: [OpenLayers-Users] Pink Tile Killing Me
>>Hello list.  I am having a problem with pink tiles.
>>Configuration:
>> I am using OL 2.5, that I download from the link at
>>http://www.openlayers.org/api/OpenLayers.js, with ms4w beta from Sept 10.
>>Running against Postgres.
>>Problem:
>>I am getting a pink tile from my wms layers in ie, but the problem is that
>>they show at different times.  Once the pink tile turns on for that layer,
>>its always there.  So for example, one of the layers the pink tile comes
>>on
>>when zoomed to max extents, any other resolution for that layer returns
>>data
>>just fine.  But once you have zoomed to max extents and get the pink tile,
>>if you zoom in, the pink tile is there but there is also data.
>>What I have Tried:
>>The layer has no max extents in the map file, nor a max extent when layer
>>is
>>added to OL.  I have set all the resolutions and I have removed all the
>>resolutions.  I have changed all sorts of settings, but can't seem to find
>>the problem.  I have a sample application, that doesn't use ol.  I have
>>tested that the data does render through this sample app, so I know the
>>data
>>is coming from mapserver just fine.
>>I am open to any and all recommendations.  I was suppose to have this
>>completed yesterday, but this is my last hurdle.  Granted it is one big
>>hurdle.
>>Thanks in advance,
>>Lee
>>_______________________________________________
>>Users mailing list
>>Users at openlayers.org
>>http://openlayers.org/mailman/listinfo/users
>>Users mailing list
>View this message in context: http://www.nabble.com/Pink-Tile-Killing-Me-tp14779152p14811157.html
>Sent from the OpenLayers Users mailing list archive at Nabble.com.
>Users mailing list
>Users mailing list
>Users mailing list
>Users mailing list
