[OpenLayers-Users] Pink Tile Killing Me
Andrew de klerk andrew.deklerk at gmail.com
Wed Jan 16 01:19:37 EST 2008
I agree, a screenshot would help. Some comments from my side. From your
discussion, It sounds like it may be a mapserver problem, so perhaps check
the following:
1. You say you have tested the maserver WMS. How are you doing this? I would
consider installing udig and testing if you can access from there. From what
I recall Udig will only accept a properly configured map file. Quantum GIS
is a little more forgiving, but also useful to test your WMS from Mapserver.
2. How are you accessing your WMS. Are you using OpenLayers.Layer.MapServer
or OpenLayers.Layer.WMS? or are you going through tilecache?
3. Perhaps try: OpenLayers.Layer.MapServer.Untiled and see if that makes a
difference
4. Are you testing a production server or a development machine. It may just
be a resource issue.
Andrew
Lee Keel-2 wrote:
> I am not sure if these have any part of what is going on with the big pink
> tile, but I have found some new information and I am trying to provide as
> much as I can until maybe someone has an idea.
> I am getting some blurred lines from my wms layers at the bottom of the
> map.  Also, I have found that I use the group name for all of these themes
> and add the group as 1 single layer, then everything displays correctly.
> I have upgraded my ms4w to 226 instead of the beta; I have added the
> temprorary fix from the "Possible Pink Tile Fix" chain; I have played
> around with all of the settings for a layer, but I have yet to fix the
> pink tile nor the blurred lines.
> I am open to any suggestions that any one has.
> Thanks,
> Lee
> ________________________________
> From: users-bounces at openlayers.org on behalf of Lee Keel
> Sent: Mon 1/14/2008 3:31 PM
> To: users at openlayers.org
> Subject: Re: [OpenLayers-Users] Pink Tile Killing Me
> Well it turns out that I can not even use this as a smoke-and-mirrors work
> around because i have some layers that won't display at all.  Not even in
> ff.  When I use the URL from firebug, I am still getting the "The
> specified CGI application misbehaved by not returning a complete set of
> HTTP headers." error.  I currently have OpenLayers.IMAGE_RELOAD_ATTEMPTS =
> 5.  I have set it to as high as 20.  Any ideas.  I am really behind the 8
> ball here.
> -LK
> Sent: Mon 1/14/2008 2:12 PM
> To: Andrew de klerk; users at openlayers.org
> you are right that its not a solution, but it is enough for me to tell
> them I have something there, and I can work on the actual solution.
> Thanks for the tip!!!
> From: users-bounces at openlayers.org on behalf of Andrew de klerk
> Sent: Mon 1/14/2008 1:42 PM
> This is definately not a solution to the reason why the tiles are coming
> up
> pink...but the following code makes it look less "error-like"
> OpenLayers.Util.onImageLoadErrorColor = "transparent";
> Andrew
> Arnd Wippermann wrote:
>> Hi,
>> I have the same problem with IE and OL. When IE failed to load a tile, it
>> shows the pink background. Then after some attempt(s) the tile will load,
>> but the pink background don't vanish. I use png as output format, but I
>> have
>> also tried with gif. But it is the same behaviour.
>> http://www.panoramio.com/photo/7120030
>> Mit freundlichen Grüssen
>> Arnd Wippermann
>> http://gis.ibbeck.de/ginfo/
>> -----Ursprüngliche Nachricht-----
>> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
>> Im
>> Auftrag von Lee Keel
>> Gesendet: Samstag, 12. Januar 2008 22:31
>> An: users at openlayers.org
>> Betreff: [OpenLayers-Users] Pink Tile Killing Me
>> Hello list.  I am having a problem with pink tiles.
>> Configuration:
>>  I am using OL 2.5, that I download from the link at
>> http://www.openlayers.org/api/OpenLayers.js, with ms4w beta from Sept 10.
>> Running against Postgres.
>> Problem:
>> I am getting a pink tile from my wms layers in ie, but the problem is
>> that
>> they show at different times.  Once the pink tile turns on for that
>> layer,
>> its always there.  So for example, one of the layers the pink tile comes
>> on
>> when zoomed to max extents, any other resolution for that layer returns
>> data
>> just fine.  But once you have zoomed to max extents and get the pink
>> tile,
>> if you zoom in, the pink tile is there but there is also data.
>> What I have Tried:
>> The layer has no max extents in the map file, nor a max extent when layer
>> is
>> added to OL.  I have set all the resolutions and I have removed all the
>> resolutions.  I have changed all sorts of settings, but can't seem to
>> find
>> the problem.  I have a sample application, that doesn't use ol.  I have
>> tested that the data does render through this sample app, so I know the
>> data
>> is coming from mapserver just fine.
>> I am open to any and all recommendations.  I was suppose to have this
>> completed yesterday, but this is my last hurdle.  Granted it is one big
>> hurdle.
>> Thanks in advance,
>> Lee
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
> http://www.nabble.com/Pink-Tile-Killing-Me-tp14779152p14811157.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users mailing list
> Users mailing list
> Users mailing list
View this message in context: http://www.nabble.com/Pink-Tile-Killing-Me-tp14779152p14868898.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080115/eabc83d4/attachment.html
