[OpenLayers-Users] WFS-T delete/update
Arnaud Cogoluegnes
acogoluegnes at sqli.com
Wed Jan 16 08:03:34 EST 2008
I finally found a hack (well, I think it is) by reading the
OpenLayers.Format.WFS.js code. Seems the typeName attribute of the update
request is mapped with the OpenLayers.Format.WFS layerName property.
The WFS layer writer (a OpenLayers.Format.WFS object) is created on demand
when the commit method is called:
/* from OpenLayers.Layer.WFS */
if (!this.writer) {
this.writer = new OpenLayers.Format.WFS({},this);
The option table is empty, so the layerName property is not initialized. So
after the WFS layer creation, I added:
if (!water.writer) {
water.writer = new
OpenLayers.Format.WFS({layerName:'G4WD:tasmania_water'},water);
I dont know if it's the correct way, but it worked (I would be happy to
know the correct way if it exists :-) )
If I find anything about the DELETE request (the FID was missing), I'll let
you know
Cheers
Arnaud
-----Message d'origine-----
De : users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] De
la part de Pierre GIRAUD
Envoyé : mercredi 16 janvier 2008 11:49
À : Yingqi
Cc : users at openlayers.org
Objet : Re: [OpenLayers-Users] WFS-T delete/update
Hi Arnaud,
I didn't use the WFS-T functionnalities for a long time now. I hope I
can throw an eye on it, but I don't think I will have time soon.
However, don't hesitate to send snippets of code so that I can
reproduce your test case.
Regards,
Pierre
On Jan 16, 2008 9:06 AM, Yingqi <anakintang at gmail.com> wrote:
> I think you should probably dig into OpenLayers\Format\GML.js to see if
fid
> is correctly retrieved when GML response from Geoserver was parsed when
you
> turned the layer. I guess fid attribute in your features are empty.
> Arno wrote:
> > Hi all,
> > I've been trying the WFS-T support for inserting polygons and it works
> > greats (polygons added in the PostGIS database, using GeoServer 1.6). I
> > tried also modifying features with the ModifyFeature Controls (based on
> > the
> > online example). Using the modifyOptions, I changed the state of the
> > feature:
> > feature.state = OpenLayers.State.UPDATE;
> > and then tried to commit the WFS layer. But I received an error from the
> > GeoServer (log traces something like "features is not available") and
the
> > transaction failed. Before asking something on the GeoServer list, is
> > there
> > anything I missed when trying to modify the feature with OpenLayers?
> > For deleting, I used the SelectFeature control, overrode the onSelect
> > method
> > to mark the feature as deleted:
> > feature.state = OpenLayers.State.DELETE;
> > and when committing the WFS layer, OpenLayers displayed a message saying
> > that the fid was missing. Same as the update question, is there anything
I
> > missed when trying to mark the feature?
> > Thanks!
> > Arnaud
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
http://www.nabble.com/WFS-T-delete-update-tp14843989p14873181.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
Users mailing list
