[OpenLayers-Users] google layer zoom
Christopher Schmidt crschmidt at metacarta.com
Thu Jan 17 07:33:00 EST 2008
On Thu, Jan 17, 2008 at 03:29:20PM +1100, Roald de Wit wrote:
> Hi Eric,
> Maria might not be using the trunk version but most probably 2.5.
> Is there a daily updated trunk version available on the website to be
> included in web pages for testing?
You can always *test* with /dev/lib/OpenLayers.js, which is updated
every 10 minutes.
There is no 'nightly build', because it seems likely to encourage people
to deploy against trunk, which I highly discourage. If you're going to
test trunk, it's not particularly onoerous to checkout svn, and build
your own copy -- and after you do it the first time, it's relatively
cheap to do it again.  In this way, you get to make the decisino on when
it updates -- which means that you can do testing yourself before
deploying.
Regards,
Christopher Schmidt
MetaCarta
