[OpenLayers-Users] Node has no parent exception when trying to
draw Polygon
samd
sdoyle_2 at yahoo.com
Thu Jan 17 16:52:26 EST 2008
Apologies but I'm now encountering the same error at a later stage with the
SelectFeature. So after doing what you suggested the polygons do render but
mousing over to select the polygon results in the same
node.parentNode has no properties error. I have even attempted to destroy
the SelectFeature and recreate it after the points are retrieved as shown in
the following.
// Create the linear ring
var ring = new OpenLayers.Geometry.LinearRing( pointArray );
// Create the polygon
var feature = new OpenLayers.Geometry.Polygon( ring );
var f = new OpenLayers.Feature.Vector(feature);
polygonLayer.addFeatures( f );
// The polygons have been rendered on the map so now recreate the
SelectFeature even though
// this should not be required.
map.removeControl( selectControl );
selectControl.destroy();
selectControl = new OpenLayers.Control.SelectFeature(polygonLayer,
{hover: true,
onSelect:
polySelected})
map.addControl( selectControl );
selectControl.activate();
Thanks once again, S.D.
Christopher Schmidt-4 wrote:
> On Thu, Jan 17, 2008 at 10:25:09AM -0800, samd wrote:
>> Hi, I originally had thought this but looking at the drawFeature function
>> of
>> OpenLayers.Control.DrawFeature on wiki it creates it.
> Um. I don't know what you're trying to do, but using the drawFeature
> control to add features to your layer is not the right solution.
>> var polygonAreaPoints = incidents[i].areaPoints;
>> var pointArray = new Array();
>> for ( var j = 0; j < polygonAreaPoints.length; j++ )
>> var x = polygonAreaPoints[j].x;
>> var y = polygonAreaPoints[j].y;
>> pointArray.push( new OpenLayers.Geometry.Point( x, y ) );
> -> now do this:
> layer.addFeatures(f);
> where layer is a Layer.Vector which has been added to your map.
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/Node-has-no-parent-exception-when-trying-to-draw-Polygon-tp14910427p14934888.html
