[OpenLayers-Users] Selecting polygon error.
Eric Lemoine
eric.c2c at gmail.com
Fri Jan 18 03:48:08 EST 2008
Do you have the problem if you remove the onSelect and onUnselect
callbaks from the select feature control options?
2008/1/18, samd <sdoyle_2 at yahoo.com>:
> Hi I was discussing this in a previous message but created a new one since
> it
> is a different topic.
> When I am using a select control on a polygonLayer such as the following:
> selectControl = new OpenLayers.Control.SelectFeature(polygonLayer,
> {hover: true,
> onSelect:
> polySelected,
> onUnselect:
> polyUnselected})
> map.addControl( selectControl );
> selectControl.activate();
> And I regenerate a polygon from points retrieved from the server such as the
> following:
> for ( var j = 0; j < polygonAreaPoints.length; j++ )
> var x = polygonAreaPoints[j].x;
> var y = polygonAreaPoints[j].y;
> pointArray.push( new OpenLayers.Geometry.Point( x, y ) );
> // Create the linear ring
> var ring = new OpenLayers.Geometry.LinearRing( pointArray );
> // Create the polygon
> var feature = new OpenLayers.Geometry.Polygon( ring );
> var f = new OpenLayers.Feature.Vector(feature);
> polygonLayer.addFeatures( f );
> The SelectFeature generates the following error on hover:
> node.parentNode has no properties
> Tracing in Firebug the error occurs here in the OpenLayers.Renderer.Elements
> class
> nodeFactory: function(id, type) {
> var node = OpenLayers.Util.getElement(id);
> if (node) {
> if (!this.nodeTypeCompare(node, type)) {
> node.parentNode.removeChild(node); // ERROR OCCURS HERE
> node = this.nodeFactory(id, type);
> } else {
> node = this.createNode(type, id);
> return node;
> Now examining the debugger the node attribute is a number such as 103,105
> etc and the type is "path"
> The only thing that I can conclude is there is something missing from the
> construction of the polygon or the addition to the layer in some aspect
> since obviously the node just being a numeric value does not have a parent
> attribute.
> Once again the values are rendered on the map but the SelectFeature results
> in this odd error.
> Anyone have any ideas?
> Thanks,
> S.D.
> http://www.nabble.com/Selecting-polygon-error.-tp14946220p14946220.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
