[OpenLayers-Users] Multiple linestrings originating from the same
point disappear when zooming
cmose
cjmose at gmail.com
Fri Jan 18 11:23:28 EST 2008
I have several lineStrings on a vector layer that originate from the same
lat/lon coordinate. As you zoom in on the map, the lineStrings randomly
disappear, e.g,. if you start out with 6 lines originating from the same
point, as you zoom in on the map lines will randomly disappear until there
are <6 lines left.
I've verified this behavior using a modified version of vector-features.html
from the examples directory. I don't have anywhere to host my example but
here is my modified script declaration from vector-features.html:
<script src="../lib/OpenLayers.js" type="text/javascript"></script>
<script type="text/javascript">
var map;
function init(){
map = new OpenLayers.Map('map');
var layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
"http://labs.metacarta.com/wms/vmap0", {layers: 'basic'}
map.addLayer(layer);
* Layer style
// we want opaque external graphics and non-opaque internal
graphics
var layer_style = OpenLayers.Util.extend({},
OpenLayers.Feature.Vector.style['default']);
layer_style.fillOpacity = 0.2;
layer_style.graphicOpacity = 1;
* Blue style
var style_blue = OpenLayers.Util.extend({}, layer_style);
style_blue.strokeColor = "blue";
style_blue.fillColor = "blue";
* Green style
var style_green = {
strokeColor: "#00FF00",
strokeWidth: 2,
pointRadius: 4,
pointerEvents: "visiblePainted"
* Mark style
var style_mark = OpenLayers.Util.extend({},
// each of the three lines below means the same, if only one of
// them is active: the image will have a size of 24px, and the
// aspect ratio will be kept
// style_mark.pointRadius = 12;
// style_mark.graphicHeight = 24;
// style_mark.graphicWidth = 24;
// if graphicWidth and graphicHeight are both set, the aspect
ratio
// of the image will be ignored
style_mark.graphicHeight = 20;
style_mark.graphicXOffset = -(style_mark.graphicWidth/2); //
this is the default value
style_mark.graphicYOffset = -style_mark.graphicHeight;
style_mark.externalGraphic = "../img/marker.png";
var vectorLayer = new OpenLayers.Layer.Vector("Simple Geometry",
{style: layer_style});
var point = OpenLayers.Geometry.Point;
var ls = OpenLayers.Geometry.LineString;
var vector = OpenLayers.Feature.Vector;
var lines = [];
var features = [];
lines.push(new ls([new point(1,50), new point(75,60)]));
lines.push(new ls([new point(1,50), new point(-60,-30)]));
lines.push(new ls([new point(1,50), new point(40,89)]));
lines.push(new ls([new point(1,50), new point(-150,-55)]));
lines.push(new ls([new point(1,50), new point(-30,-25)]));
lines.push(new ls([new point(1,50), new point(-5,-10)]));
for(var i=0;i<lines.length;i++){
features.push(new vector(lines[i], null, style_green));
map.addLayer(vectorLayer);
map.setCenter(new OpenLayers.LonLat(1,50), 5);
vectorLayer.addFeatures(features);
</script>
The map is initialized with a zoom level of 5. Once you get to 8 one of the
6 lines disappears, leaving you with 5. Zoom level 9 removes all but one
line. Zoom level 10 removes all lines.
I haven't traced the issue beyond drawFeature() in Vector.js. I've tested
the example in Firefox thus far but in my app I'm getting the same behavior
in ff and ie.
Any ideas?
View this message in context: http://www.nabble.com/Multiple-linestrings-originating-from-the-same-point-disappear-when-zooming-tp14952551p14952551.html
